Panasonic TXP50 S21 B
    When this Tv is switched on the relay is heard to click , the tv won't come to life , the front LED flashes 4 times.
    Re: Panasonic TXP50 S21 B
    I have just done a few quick tests and found the resistance across the SC board power connection is 12 ohms , the reading across the SS board power connector is around 1 .3 Meg Ohm. Does this seem too high a resistance across the SS board supply ?
      wrong question. does 12 ohms appear to be a short cct on the SC?
      answer is yes. I would use the search function and target posts on any 2010 FHD model and also TNPA5105 or even TNPA5081.
      There will be plenty of info but basically the SC has shorted, that shorts the P board, that then triggers SOS 4. other common code would be 10 blink.
