Toshiba 32BV500B suspected panel fault
  • notallbad
    • Oct 2012
    • 1183
    Would everyone here tend to agree?
    PS - 17PW26-4
    MAIN - 17MB45M-3
    PANEL - LTA320AP06
    INVERTER - SSI320-4UA01
    TCON - 320APO7S4LV0. (can't quite see the ver. no.)
    PS b/d voltages in stby and powered on check out ok.
    Odd behaviour - no led status on the front panel in either stby or when switched on, in stby the TV still beeps when the front buttons are pressed i.e vol and channel up/down buttons, also insert a USB drive and the TV shuts down. Otherwise operates as normal.
    Picture is the main issue, see attached photos. It doesnt show like this immediately after switch on, it slowly 'bleeds' down the screen, eventually the whole screen whitens.
    Remove the T-con cable and just shows a backlight blueish/black screen with no distortion, kind of expected I guess. Just for added info.
    Menu shows fine.
    Input source (HDMI) shows fine.
    Photo of PS b/d voltages also added.
  • notallbad
    • Oct 2012
    • 1183
    Re: Toshiba 32BV500B suspected panel fault
    OK, so there is a front panel LED, in stby it is lit white very dimly, when the tv is on it goes out.
    Obviously not an on/stby light! Perhaps for fault diagnosis but its not flashing in this TV.
    • notallbad
      • Oct 2012
      • 1183
      There are 2 LD1117AL regs on the main bd.
      In 7.89v, out 1.2v relative to gnd pin
      In 2.56v, out 1.2v relative to gnd pin
      • notallbad
        • Oct 2012
        • 1183
        On the T-con bd 320AP07S4LV0.4 theres an A1718.
        2SA1718 PNP Power transistor.
        With power applied volts read, relative to gnd point:
        Base 13.9v
        Collector 0v
        Emitter 14.29
        • dskall
          • Oct 2016
          • 2905
          • usa
          Just my opinion but doesn't seem like a panel problem
          • Davi.p
            Hobbist
            • Sep 2009
            • 4264
            • Italy - Milan
            Hi, it is a very common problem with Samsung panels, i would like to ask you if you can measure esr or ripple out the power bd on 12v line. Second test, disconnect one at a time the ribbon connec. between tcon-panel and take a picture of the result, please scale pictures when is possible that slows down page.. Third try, locate CPV1, CPV2 testpoints on tcon and with continuity see to which pin goes on the connector, then put a small stripe of tape on that single contact on the ribbon, in turn first CPV1, second CPV2, then if there are significant changes post them here.. Bye
            • notallbad
              • Oct 2012
              • 1183
              Took soom readings from the 'T-con' bd.
              All relative to the T-con gnd point.
              VCNT 6.95v
              VCOMS1 6.14v
              VCOMG1 6.14v
              VCST1 6.14v
              VCOMS2 6.14v
              AVDD 13.9v
              DVDD 3.0v
              VON 25.7v
              VOFFE -11.12v
              IN 11.51v
              VIN 11.51v
              SCL_II 0.6v
              SDA_II 0.69v
              VDDT 3.08v
              RVDD_DIG2 3.08v
              RST 3.01v
              TCON_RDY 3.07v
              VDDOP_RSDS 3.08v
              SDA 3.07v
              SCL 3.07v
              WPP 3.08v
              EVDD 3.08v
              VCOMS3 6.15v
              REV 1.57v
              TP 0.16v
              CKV2 7.32v
              CKVB1 7.36v
              CKV1 7.3v
              TMP_FB2 1.83v
              VCST2 6.13v
              VCOMG2 6.15v
              VCOMS4 6.15v
              CVO 8.32v
              VR 8.44v
              • notallbad
                • Oct 2012
                • 1183
                thanks for reply.
                1) unfortunately I do not have a working scope
                2) the ribbon cables to the 't-con- bd are heat bonded on at both ends
                3) CPV1 & 2 must be named something else on this board, please see post above with 't-con' test point volt readings
                The T-con bd is not the usual type that usually sits between the main bd and the panel bd, it is the panel bd or perhaps video processed /scaled etc on the main bd which is more likely.
                • notallbad
                  • Oct 2012
                  • 1183
                  USB problem resolved. Well wasn't a fault.
                  Plugged in an external hdd thats usb3.0, power draw must have been too large as the TV's usb port is 500mA max.
                  Plugged in a 2gb USB stick (needs to be formatted fat/fat32, I think) and plays films perfectly fine.
                  Well at least thats one less issue. User error fortunately.
                  Still just leaves the main issue of panel distortion.
                  • notallbad
                    • Oct 2012
                    • 1183
                    For info.
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      I wonder if you have a mainboard fault. The menu details all look fine and no characters are missing.
                      • Davi.p
                        Hobbist
                        • Sep 2009
                        • 4264
                        • Italy - Milan
                        "unfortunately I do not have a working scope" I have never spoke about scope, it is not necessary.
                        "it is the panel bd or perhaps video processed /scaled etc on the main bd which is more likely." I dont understand this sentence, sorry, you are meaning that the tcon is integrated to the panel, so is large as the panel and deep few cm?
                        CPV1,2 in your tcon is CKV1,2 , have you understood my suggestions? I have never done this test and i can't do now because i have damaged the only one tv that i own with this sympthom. Sorry, but there's no risk.
                        • notallbad
                          • Oct 2012
                          • 1183
                          Sorry, misunderstood.
                          1) If correct, DMM on ac setting, probes across chassis ground and +12v. Reading is 25.5v ac.
                          2) There is no T-con bd! Its either integrated on the main bd or it is the board that is heat bonded onto the top of the lcd panel. If I remove the bonded connectors there is no way I would be able to rebond them back on.
                          3) I do understand your suggestion and shall try it when I have more time on my hands - the panel has been re-assembled due to lack of working space, little children and inquisitive hands.
                          Thanks again for your help, appreciate it!
                          • Davi.p
                            Hobbist
                            • Sep 2009
                            • 4264
                            • Italy - Milan
                            1) I have never asked you to measure any voltages, only ESR or ... ehm sorry, yes i've asked for a view of the ripple, but you don't have scope, so an esr meter?
                            2) ok, since i recognize tcon marking, it is a Samsung, mainb. is Vestel, so tcon is integrated in the panel..
                            Bye..
                            • notallbad
                              • Oct 2012
                              • 1183
                              Yes, have an ESR-2501A ESR METER, cheapo meter compared to most others.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                This seems like a common issue on this model
                                https://www.badcaps.net/forum/showth...shiba+32BV500B
                                out of curiosity its the lcd/tcon pcb on the top or bottom of the tv, there was a thread a while ago where the tab bonds was on the bottom of the lcd panel and someone had cleaned the screen with liquid which had then ran down onto the board and caused corrosion etc just though i would mention it.
                                • notallbad
                                  • Oct 2012
                                  • 1183
                                  Located on the top. Have inspected the board and looks ok.
                                  Anyone know if the tcon can be powered independently?Though I suppose it would need more than just the 12v and gnd feeds.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    thats handy too know for future reference thanks.
                                    • notallbad
                                      • Oct 2012
                                      • 1183
                                      Yes it would seem my symptoms are the same as the thread you posted above. Might be best just to ditch the panel.
                                      thanks vince
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        Its a pity in the other thread was not updated to see if they found the problem or not, but the other thread does look like exactly the same issue.
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
                                          09-06-2024, 05:33 AM
