Panasonic TC-P42GT25 8 blinks
  • freelancenoob
    • Oct 2017
    • 77
    I have a panasonic on the bench now. 42" 3d plasma. It turned on and worked perfect for 10 minutes. Then the tv shut off and started blinking the red power light. Blinks 8 times then pauses. Can not turn the tv back on until I unplug the system and wait a little bit. Then same process all over again.
    I went by this troubleshoot
    https://www.manualslib.com/manual/83...page=17#manual
    8 blinks says to check SS & SS2 board.
  • AnthonyC
    • Oct 2017
    • 10
    Re: Panasonic TC-P42GT25 8 blinks
    This manual helped me out on mine (P50G25). It's for the G series, not GT, but I imagine much of the troubleshooting steps are similar.
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      Usually the SCBoard goes defective on these models.
      Did you tighten all screws? Normally when a SS or SC board goes defective it stays defective ( FETS shorted for example ).
      This could be a BGA problem on the mainboard. Tv turns on , board gets hot , solder gets loose and board thinks there is a problem with the tv and shuts down.
      Tv is probably fooling you with the blink code.
      • freelancenoob
        • Oct 2017
        • 77
        https://www.manualslib.com/manual/11...?page=2#manual
        Found this manual also. Its the correct one for my tv and not the one I posted in the original post.
        I'll go through and make sure all the screws are tight and see what happens.
        • freelancenoob
          • Oct 2017
          • 77
          While I was tightening screws I decided to do a continuity test on a few things. No power to the system I get pass through on 2 of these chips. Rest all have resistance. Swapping probes around gave same results. Does this mean anything?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Do you have 0 reading between the middle pin and either or both of the outer pins?
            • freelancenoob
              • Oct 2017
              • 77
              All the readings are from outter leg to outter leg. I just went back and put negative on center leg of each one. I can only get a reading on center leg and right outter leg on those that gave a value. That reading is just about 300. Now on the 2 that gave 0 i can touch center to right and get little over 300 and i can also touch center to left and get same reading.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                What are the part numbers on them?
                • tw2005
                  • Oct 2011
                  • 6458
                  All normal and the ones in question are diodes
                  • tw2005
                    • Oct 2011
                    • 6458
                    any arcing sounds (crackles)? may be worth pullings the boards and removing any dust build up. Could be a long shot. Visually I don't see what I'm looking for but I had a 65" 2009 which did something similar. Heard arcing on the SS, turned the lights off and I could see it jumping from the board to chassis.
                    The large blue polyester caps were failing, had cracked and as it warmed up arced and 8 blink.
                    But could be a false detection and A board could be letting go with heat, tough one.
                    I think you would need to find the SOS8 line and see if it's changing level at the same time it shuts down the TV.. If the SOS 8 line is not coimanding the A board to shutdown then very well be the A board.
                    Can't comment from experience on this one. SS boards may be cheap enough if you want to gamble
                    • tw2005
                      • Oct 2011
                      • 6458
                      Mrs reckons I keep too much crap. I strongly resent that accusation.
                      Oh, found the cap, LOL Now I've picked at it and pulled it apart a bit but it was cracked and swollen
                      • freelancenoob
                        • Oct 2017
                        • 77
                        I found TPSOS8 in the bottom right corner of this photo. Is that the one you speak of? I pulled this from an ebay photo identical to my board. I have a board that overlays this board so I haven't taken it that far apart yet.
                        • tw2005
                          • Oct 2011
                          • 6458
                          yeah, good spot to start. Don't remember if it's a high or low that triggers. Probably fin in a training manual for that series it'll run you through checking this anyway. you'd have to have a look. Any 2010 series trainer will do
                          • tw2005
                            • Oct 2011
                            • 6458
                            I don't much more time, see where this takes you.
                            • tw2005
                              • Oct 2011
                              • 6458
                              That could be wrong slide, better check this one first. grabbed the other in a rush
                              • freelancenoob
                                • Oct 2017
                                • 77
                                TV powered on that pin has no voltage. Waiting for tv to warm up and shutdown with the blink code to check it again.
                                • freelancenoob
                                  • Oct 2017
                                  • 77
                                  Now the blink code is back and still no voltage on that point.
                                  • freelancenoob
                                    • Oct 2017
                                    • 77
                                    Well I followed the second diagram. I unplugged ss33 and powered on the tv. Tv stayed on but I had no video. So I did both options. I checked all connections and they were all fine. I checked continuity on the 3 connections that connect to the ss board. Those all checked out. Since the continuity checked out it tells me to replace the ss board. But since the tv powered on but no video does that mean my A board needs replaced?
                                    • Moreno83
                                      • Jun 2014
                                      • 2008
                                      • The Netherlands
                                      When either the SS or SC board fail the tv wont turn on AT ALL! Unless a bad cap as TW2005 said. A shorted diode or FET stays shorted.
                                      My guess is a bad mainboard! Especially as the tv shuts down after a while....that is heat causing the problem. Can you touch the mainboard or is it to hot to touch
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        Depends, You say it does not 8 blink straight away. so was it on long enough to prove anything?
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • CrewmanRedShirt
                                          Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                                          by CrewmanRedShirt
                                          Hello all,
                                          As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                                          07-13-2024, 11:02 AM
