Sony KDL-46HX800 Ethernet Port on Main Board
  • kevinm34232
    • May 2012
    • 1884
    This TV can only be hardwired for internet connection (or there's a WiFi dongle I think). But anyway long story short, after I was done doing updates via ethernet, like a dumbass I forgot I had that cable connected, moved the TV, and yanked it right off the board.
    I looked at the board and as far as I could tell, there was no damage but the RG45 connector outer piece had come apart, the pins were all still in place and it didn't seem to damage the board itself.
    But now internet won't work. I've looked closely and can't see an issue. So I found another salvage main board and changed the connector out, but still nothing. (also tried a new ethernet cable from a different connection, although the original one still works on another device.)
    I'm not going to spend much more time on this but I thought I'd ask if anyone had some ideas as to what to test?
    Or even if there's a USB device that can plug in to hardwire instead of just WiFi? Looks the like the WiFi adapter has to plug into the ethernet port tho
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • ygorsan
    by ygorsan
    🧩 Problem Summary:
    • I
    07-28-2025, 08:34 AM
  • JDC
    (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
    by JDC
    ONN 100012588
    Issue: No Power, Then Rebooting After Main Board Change
    Short answer: replace main board and power board
    Technical answer: replace main board and Q306 & Q307 on power board.
    Long answer:
    TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
    07-15-2022, 07:39 AM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
