back up vestel firmware ?
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    Hi guys i have 2 replica tvs with same panel, main etc.
    i have updated one of the boards and the screen is flipped upside down.
    my question is, can i backup the firmware on one through the service menu and then reinstall the firmware on the other tv ?
  • heavymachines
    • Mar 2011
    • 1028
    Re: back up vestel firmware ?
    If they're the same yes, it may require a cheap usb $14.00 spi flash device from ebay to do the backup and transfer. Unless your tv has a backup feature in menu.
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      it doesnt unfortunatly. not that im aware of anyway.. where is exactly is the IC that holds the firmware on the vestel boards ? woukd a soic clip be ok for doing it. have an 8 pin one around somewhere.
      • heavymachines
        • Mar 2011
        • 1028
        Take a photo of the main and we will point it out for you. Good clear straight shot high res photo.
          17MB6x Vestel uses two NAND devices for firmware, one for mboot and one for the main application,.
          Main application one is much larger, TSOP48 package (google it), typically near the Freeview card slot.
          Mboot one not a concern if the set is running, has little to do with the operation once it's booted.
          • Bazilwrc164
            Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
            by Bazilwrc164
            I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
            The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
            I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
            If anyone can provide:
            • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
            • Or a compatible EEPROM dump
            07-23-2025, 12:15 PM
          • massimomax
            Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
            by massimomax
            Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
            spero che qualcuno può averlo per riprogrammare eprom. grazie
            Post in English !!!
            I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
            02-28-2025, 07:27 AM
          • lberkani
            Request: USB firmware for Toshiba 65UL2163DG (Vestel 17MB180E) - panel VES650QNTX-N2-N42
            by lberkani
            I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
            The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
            The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
            I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
            - Toshiba 65UL2163DG
            - Vestel 17MB180E mainboard
            - Panel VES650QNTX-N2-N42
            - Version V1.28.100.0 if available
            If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt...
            11-11-2025, 12:37 PM
          • karlox
            Request for EEPROM Firmware Backup – Epson PowerLite S18+
            by karlox
            I have an Epson PowerLite S18+ projector in the workshop showing signs of a firmware fault. I’ve checked all voltage lines and signal paths, and everything seems within normal range.
            Here’s the issue: when the power cable is connected, the power LED immediately turns blue even though the projector doesn’t start. When powered on, the fans run but the lamp never ignites. After a few minutes, both the temperature and lamp indicators turn red.
            I’m attaching the backup I read from the IC in case it’s useful for analysis or comparison.
            If anyone...
            10-16-2025, 07:48 PM
          • anlu
            Vestel Firmware - Toshiba 32W133DN
            by anlu
            Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
            Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
            02-04-2023, 12:59 AM
