60PA6500 - Same old problem, no picture but sound
  • chood2
    • Oct 2017
    • 11
    Hello all!
    Been doing some research and I can't find anything that covers what I'm looking for, besides this:
    https://www.badcaps.net/forum/showthread.php?t=18542&
    I have a LG 60PA6500 that currently turns on and has no picture but sound.
    I'll explain my situation. I'm a college student looking to fix this broken TV - I have resources for all the DIY I may need, from reflow soldering to oscilloscopes and infinite amount of testing equipment and supplies. This can be fixed, but I need to figure out what's wrong on it - That, I don't have much experience in.
    Here's some additional information:
    1. The control logic board does not flash at all - the 5V bus is getting power. The main board has a constant red light when I power it on. Can't find any information about if the logic board has no light!
    2. Where are schematics? Are there none? I feel like there's gotta be some service manuals or something -- All I can find is for the main board, which I would love to have for the other boards...
    3. I have replaced the left hand side (top and bottom) buffer boards, also tried per a forum/website to disconnect the Y and Z from the power supply -- no dice.
    4. Measured voltages -- Everything looks good with 5V, VA, VS --
    5. Obviously the fuses are all good to go... (Including ones that don't necessarily look like regular fuses)
    Where to start? I'm thinking/hoping if I can just replace the control logic board it'll fix everything but that might not be the case...
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: 60PA6500 - Same old problem, no picture but sound
    You have stable VA,Vs. Have you tried to force test patterns?
    Service manual: https://www.manualslib.com/manual/11...-60pa6500.html
    • chood2
      • Oct 2017
      • 11
      I'm not sure how to force a test pattern! Couldn't find the exact details for this model. How do I do this?
      **EDIT**
      I found this:
      "OK, on the CTRL board you can see a pair of holes on the bottom right hand of the board marked EXT AUTO GEN.
      Turn the TV power off (unplug the set)
      Place a wire link between these holes
      Disconnect the LVDS cable between the main board and control board
      Plug the TV in...do the test patterns cycle continuously?"
      Will test and come back.
      • tw2005
        • Oct 2011
        • 6458
        good idea, I'd start there
        • chood2
          • Oct 2017
          • 11
          Hi all, went ahead and tried to connect the EXT pins, disconnect the main blue connector (as shown on the right), and see if I get a test pattern. No dice.
          Thoughts?
          Click for Picture
          • chood2
            • Oct 2017
            • 11
            What might be some standard FETs or areas that go bad?
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • slimmy182
              [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
              by slimmy182
              Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
              I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
              Looking on google I found this:...
              01-14-2023, 11:55 AM
