HP CPTOH-0602 "Actually an LG"
  • heavymachines
    • Mar 2011
    • 1028
    Ok picked this up today for free 42" plasma and it is old manufactured in sept 2006 and it is an IPM Hybrid plasma.
    Took the back off and started testing around sure enough as i suspected we have a shorted IPM on the X er Zmain same damn thing, VS is shorted to ground and 1 blown fuse out of 2. the guy i got it from told me the y main was replaced 4 years ago. IPM appears to be ok no shorts on Y main.
    Now see if i can locate some parts as it may be very hard.
    Getting genuine IPM may be impossible this day in age been some years since i dealt with a hybrid plasma. But it was straight forward on figuring out.
  • heavymachines
    • Mar 2011
    • 1028
    Re: HP CPTOH-0602 "Actually an LG"
    Part number for the Z sustain is LG 6871QZH956A
    Panel sticker is one that shows va and vs voltages is PDP42X3####
    There is another panel sticker shows this part number PDP42X32002.
    Now find out the STK numbers for the IPM.
    • heavymachines
      • Mar 2011
      • 1028
      Substitute part number for IPM is STK-795-821
      • heavymachines
        • Mar 2011
        • 1028
        Ok ordered Z-sustin. The IPM itself was more expensive like $38.95 from coppel not including shipping and the pain of changing it. Other sources was cheaper but from china and most likely fakes.
        So the Z-sustin is going to set me back $29.00 and $8.00 in gas picking it up as it was 18 miles each way. So total is $37.00 Not bad. Stay tuned when i report results.
        $37.00 is the total all i have into this set so far.
        • heavymachines
          • Mar 2011
          • 1028
          certain you're supposed to replace both IPM in pairs but hey the last guy only replaced the y main and got 4 years of use. Not going to worry about it too much.
          • heavymachines
            • Mar 2011
            • 1028
            Ok replacement z sustin is in and tv is alive and well
            • ArMaaN376
              Samsung PS51E550 Plasma TV
              by ArMaaN376
              I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
              Opened TV cover & observed foll
              a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
              b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
              c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
              How to confirm Y -Buffer board...
              06-19-2024, 04:05 AM
            • jm1234
              Panasonic plasma TX-P42ST50 - 6 blinks
              by jm1234
              anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
              It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
              I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
              I checked that board for any obvious faults...
              05-22-2024, 06:59 AM
            • KYBOSH
              Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
              by KYBOSH
              Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
              No picture but you hear the TV static (white noise) playing loud and clear.
              The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
              But it seems they didn't get too far and just left it.
              When I first took a look I was amazed at how pristine the inside looked.
              Its as if the TV had been in a time capsule.
              Caps looked like they were just pulled off the self.
              Copper coils had no sign of corrosion on...
              02-01-2023, 11:10 PM
            • chazh
              LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
              by chazh
              This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
              I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
              The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
              09-01-2025, 08:56 PM
            • porfyriadhs
              Samsung Plasma PS51D6900DS Bootloop
              by porfyriadhs
              Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
              Thanks a lot !!
              10-19-2023, 11:31 AM
