Sony kdl-42w705b no video no audio vertical stripes
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4456
    • Italy - Milan
    I need help on how to run the screen test mode by the service menu without seeing the video out, entering SM is easy but after i know i have to press Option 2 times to go to the VCP part, then i have to access menu 005, this by pressing "2" 5 times i think and then? There'no explanation on service manual about this Test pattern menu, what i have to press? Thankyou so much bye bye.
  • tw2005
    • Oct 2011
    • 6458
    Re: Sony kdl-42w705b no video no audio vertical stripes
    If the 42" panel is AUO or anything like the 50" version, panel has probably crapped itself. Got a 50" here, totally disgusted and having read up a bit, seems common failure and about 3 years is it.
    another reason I still love my panasonic, plasma, I can fix the boards, panels are generally pretty solid.
    I'm hanging on for Tv with the same panel to do a rebuild.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4456
      • Italy - Milan
      The bad panel is major percentage, but i need to be sure, usually vertical lines have an image under them, here there isn't. I don't know if i can try the trick of lvds cable detached, externally supplied 12v and jump 3,3v<>pin41 like some LG panels.. i have to try with a bad panel that i have first..
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4456
        • Italy - Milan
        Hi, i was inspecting the tcon 'cause i have some hopes about it and when i was testing the usual voltages i found a cooked resistor, a boubble on top of it and boubbles around it on the pcb, despite of this it measures good for what i can see, the marking was slightly visible, it was 1R80, it is part, for what i can recognize, of a charge pump power supply for the VGL, that it measures a bit high for me (-4,8v), the Res. go to a condenser that measures 225nF detached, that goes in the middle of a series of 2 identical power low drop (0,167v) diodes, one with cathode to GND, the other with anode to a big transistor that goes to VGL testpoint. The other voltages are correct apart VGH that is low (11v). VGL is near a multipin AUO chip that is its controller i think and that produces also AVDD and is for me half toasted, in the other side of the card there's another AUO chip that produces VGH from a normal boost converter (big inductance visible). I don't know why also VGH is bad but i think the pwm of its controller is keep off by a control in the chain of the voltages that senses the bad VGL.. I'm here to ask you if i'm good if i feed from external a good VGL around -6 or -7v to see what happens? Bye..
        Ah, forget it, the cooked resitor measures 12v and 0hm to the 12Vin of the board..
        also the question is odd since the voltage control is made probably or surely by the same chip i suppose cooked..
        • tw2005
          • Oct 2011
          • 6458
          Sorry, very inexperiened with LCD but I can say I swapped a good Tcon into a bad panel not knowing watched it cook in a another AUO panelled TV.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4456
            • Italy - Milan
            thanks, i found a bad Linear regulator, it's sot23-3 and i don't find the right marking code equivalence for now (25FS1, maybe S1 is production lot).
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4456
              • Italy - Milan
              Anyway if someone can tell me the Vout of this reuglator i thank him very much.. now i'm stuck on it, it's easy to find the pin assignment, but the Vout is at least impossible. One can connect an external DC-DC reg and trim it live but i think is not the only piece broken on this board.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4456
                • Italy - Milan
                I found a very little hole in the second tensions generator(+buffers) chip, so i have ordered a new tcon from China, all the tcon in the market are from another tv model so i have to swap the eproms before start. Also bought the chips..
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Sounds just like the motherboards during the classic bad caps motherboard era! Especially during the single core era. Eww!
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4456
                    • Italy - Milan
                    The tv is 3 years..
                    • alro7779
                      Samsung UN55MU6103F video problem; has colored stripes on the display
                      by alro7779
                      Hello, everyone!
                      A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                      09-27-2025, 11:29 PM
                    • halen
                      Hisense H55U7B vertical stripes
                      by halen
                      I have Hisense H55U7B TV with no picture, only big vertical stripes. I did several tests and I'm not sure, where is problem.
                      1. Connected tcon to 12V, white, red, green, blue, black picture visible in cycle on full LCD without error
                      2. Connected only left side of LCD to tcon, big stripes
                      3. Connected only right side of tcon, visible normal picture on the right. Working as expected.
                      Where could be problem?
                      Tcon RSAG7.820.7932/ROH
                      Main board RSAG7.820.8698/ROH
                      Jan
                      06-18-2025, 03:58 AM
                    • bbenalmadena
                      Old Sony VAIO da0hk5mb SVE1512E1E disable Radeon video card
                      by bbenalmadena
                      I have a Sony VAIO SVE1512E1E (motherboard da0hk5mb) video card is broken, has artifacts, I want to disable it, the processor is an I3-3110M that supposedly has an integrated Intel GPU and I want to disable the onboard Radeon so that can be used.
                      I download some schematics, and tried to remove VPL1, but then the laptop starts some leds, and shut off. Should I try to lift VPL1 and VPR47 and pass a cable to one tip of VPR47 and the other back to VPU1 to see if that works or it is pointless?
                      That seems to be some feedback to VPU1 and I guess if it does not detect voltage, laptop...
                      08-30-2025, 10:40 AM
                      HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                      This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                      09-12-2024, 02:00 PM
                    • ahoonid
                      MacBook A1990 vertical stripes on external screen
                      by ahoonid
                      Hey everyone,
                      I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
                      The board is neat. Not opened before for sure. Just a little dust, nothing more.
                      Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
                      06-20-2025, 08:54 AM
