Panasonic plasma main board compatible
  • hienton2
    • Sep 2009
    • 183
    Hello everybody
    My panasonic plasma tc-p50c2 main board has number TNPH0831 3A is bad.
    My friend has good panasonic tv tc-p42c2 main board has same number TNPH0831 3A . MY question Can I swap these main board.
  • heavymachines
    • Mar 2011
    • 1028
    Re: Panasonic plasma main board compatible
    I would imagine if they look identical with same plugs and pinouts it would probably work if not the firmware would need to be swapped might want to wait for a 2nd opinion from others who are far more knowledgeable.
    • tw2005
      • Oct 2011
      • 6458
      If they are both C2 models the boards should have the same features. o yes you could, then just get the respective manuals and compare the part numbers alloctaed to the EEPROMS , SPI , flash chips etc. The ones that re different either physically swap or get an EEPROM programmer and copy/save data for each then write over the new boards chip with your data.
      If you did this for all except the large flash chip which you won't have to touch, all settings, history , run hrs would transfer too.
      I've done a few conversions now, fun way to fix when you can't get the exact original board.
      • johnboy1313
        • Nov 2012
        • 1959
        I think I tried this exact swap once and the boards turned out to be different. They had different plugs that wouldn't allow the swap. I could be wrong though.
        • tw2005
          • Oct 2011
          • 6458
          That should not be the case for this one, sounds like maybe an attempt with an S model for a C. Same board PCB but FHD to HD so none of the ribbon connections would be the same for sure.
          all you blokes need to do is jump on SJ and search the PCB number and do a comparison, then get the manuals, identify the eeprom versions / variations, adjust accordingly
          • hienton2
            • Sep 2009
            • 183
            Thank you TW2005 and Johnboy1313. I better wait for somebody sell same main board
            same model onsale to buy for good price.
            I need main board for model TC-P50c2 anybody has please contact me.
            • tw2005
              • Oct 2011
              • 6458
              Or get PTS to refurb it
              http://www.ptselectronicsinc.com/txna1lfuus/
              • stecos
                Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                by stecos
                Hi everyone!
                I happened several times, in the search for help from the web, to consult this very interesting forum.
                So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                Having said that I come to the gist of my post on the forum as the title suggests.
                For my passion for technology I'm now collecting several...
                11-28-2022, 11:39 AM
              • Dani_2024
                by Dani_2024
                10-28-2024, 05:06 PM
              • ygorsan
                by ygorsan
                🧩 Problem Summary:
                • I
                07-28-2025, 08:34 AM
              • jb_Bak
                by jb_Bak
                CN6401
                Pin 01 NC
                Pin 02 NC
                Pin 03 "BL_ON": 0V
                Pin 04 "N/C"
                Pin 05 "STBY 3.3V": 3.5V
                Pin 06 "GND": N/C
                Pin 07 "AC_OFF"...
                09-27-2021, 04:52 PM
              • tvguy12012012120
                Picture degrades over ~2–3 minutes (washed out / low contrast) – panel vs T-CON/FRC vs main board diagnosis help
                by tvguy12012012120
                I’m troubleshooting a Westinghouse WD55UW4620 with a strange, very repeatable failure mode and I’m looking for insight on whether this points to the panel itself, T-CON/FRC board, or mainboard.
                Any ideas as to what would cause these symptoms?
                Symptoms:
                • From cold power-on, picture is perfect.
                • After ~2–3 minutes, the image slowly degrades:
                  • contrast collapses
                  • colors wash out / look incorrect (greens especially bad)
                  • image looks “milky” / flat
                • Turning the TV off for a few minutes fully resets it; behavior repeats almost exactly each time.
                • Internal
                01-07-2026, 03:30 PM
