How I repaired a Toshiba 32" LCD
+ More Options
Posts
  • Dumah Brazorf
    • Jun 2013
    • 179
    • Italy
    I successfully repaired a 32AV734G1 by Toshiba striked by a lightning.
    Sorry i forgot to take photos...
    I found signs of an electric arc on the chassis under the main line connector of the power board so I focused on that board initially. It's a 715g3714-p01-h20 (vestel crap?) Found the schematic here.
    Main fuse F901 blown, inrush thermistor limiter NR901 destroyed, main bridge rectifier BD901 shorted ac to negative, R955 bad. Also changed Q970 and Q971 for good. Checked all the diodes and all caps and the cold side of the board for shorts. All green.
    Fired it up... quite literally. R958 and IC950 smoked out. IC950 is a A6069H PWM controller with integrated mosfet. The mosfet was shorted out, probably I didn't figured out in precedence, and killed the resistor. Found one of the zener diode ZD951 around IC950 not reading good.
    Now the power supply didn't power up, 5V not present. 5V is produced by the transformer driven by IC950. All diodes, resistors and caps around IC950 measured good so I finally changed all zener left on the hot side of the power board. That worked.
    Checked the main tv board and the inverter board of the tv. No signs of whatsoever, no shorts.
    Reassembled and tested for some hours. So good so far.
    So, the lesson of today is: never trust a glass zener!
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: How I repaired a Toshiba 32" LCD
    Thanks for sharing repair
    • koka0011
      • Apr 2013
      • 30
      • Sri Lanka
      thanks for the information
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
        09-06-2024, 05:27 AM
      • atltechnology
        Toshiba Satellite L50 PSKXWA-01100M Schematic Diagram Board View
        by atltechnology
        I need the Toshiba Satellite L50 PSKXWA-01100M
        This is my board no : daobltmb8fo rev f
        model no : Toshiba L50D-C
        Part no : PSKXWA-01100M
        Give me Schematic Diagram Board View
        01-14-2025, 04:21 AM
        Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
        This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
