Sony LC-32D4U
  • jazzie366
    • May 2016
    • 304
    Sony LC-32D4U
    *screams internally*
    Okay, so this thing has decided to be the biggest little shit of the century.
    It has the common problem of the heatsink material melting, shorting the output sound IC and causing a no sound condition. You'll hear a mini pop sound upon turn on that indicates this condition is here.
    Well, I replaced the pad, cleaned the circuit board till it was SPOTLESS. Using Acetone, CorrosionX, Alcohol, and CRC QD electronics cleaner. Literally nothing will stop this madness. I have resoldered each pin under a microscope using a needle point soldering tip and a very hot soldering iron, 400C. So, after all of that, it still makes a little pop and produces no sound.
    The customer has indicated that after a chromecast was used, the audio never worked after that.
    Can someone point me to what I should do? The IC is very cheap and I can replace it no problem. I don't want to because fuck all of those pins.
    Popcorn.
  • jazzie366
    • May 2016
    • 304
    Re: Sony LC-32D4U
    Update to this:
    Magic smoke released itself from the mainboard. Turns out there was ANOTHER one of these shitty pads on the bottom of it, a SMD resistor smoked itself and the pad had melted itself onto many other components of the board. Basically, board's fucked. It's cheaper to replace it entirely than to waste the labor on trying to fix it any further. Getting a fresh board for this unit and going to fix it from there.
    Popcorn.
    • Vitam
      Class A Geek
      • Aug 2017
      • 45
      Re: Sony LC-32D4U
      Just buy a new TV - this whole thing seems like a shitload of fuck (just like the AVGN always says). I had a Samsung (samsuck/samshit/samsham) DLP TV and it was working OK until - boom - it's out. Lamp, color wheel, inverter, DLP chip and all boards are fine. Ended up spending so much money on it. I returned all the parts, got my money back, took the thing to the back porch and threw bricks at it then rolled it to the curb, All that was left was a pile of glass and plastic and metal. It was from 2008. At the mid day point, it was cloudy out and I really wanted a projection TV. Walked outside and just down the road is a nice big 2004 Sony LCD projection TV. Hauled it home, thing works. Neat.
      So, almost all the new Sony TVs like this are crap. Garbage. Made by some Chinese company.
      • Vitam
        Class A Geek
        • Aug 2017
        • 45
        Re: Sony LC-32D4U
        Actually, what you have might be a Sharp set. Made by Vestel, the worst of the worst of the worst of the fucking worst.
        • ChaosLegionnaire
          by ChaosLegionnaire
          09-13-2022, 09:02 AM
        • Akuanka
          Sony SLV-E780 Power Supply Issue – Clicking Sound, Need Help Identifying Faulty Component
          by Akuanka
          I'm troubleshooting a power supply issue with a Sony SLV-E780 VCR. The device clicks repeatedly but doesn't power up completely. I've already replaced five capacitors, but the problem persists.
          Here's a video link https://photos.app.goo.gl/3Xki6yvCLn67gLX78​ showcasing the sound. Based on your experience, could this be due to a transformer, diode, or another component? Any guidance on what to test or replace next would be greatly appreciated.
          Thanks in advance for your help!
          11-23-2024, 01:12 PM
        • KYBOSH
          Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
          by KYBOSH
          Previous owner said TV just went blank one day.
          They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
          Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
          The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
          There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
          I just downloaded the Sony KD-75X7800F Service Manual and...
          11-19-2024, 10:12 AM
        • x_orange90_x
          Sony Bravia KD-50X690E NO SOUND
          by x_orange90_x
          Finally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
          Has anyone else had this happen to their tv?
          10-05-2024, 05:01 AM
        • Audeze
          Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
          by Audeze
          I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
          Does...
          10-06-2024, 08:54 PM
