Panasonic viera Txp50vt30e dark screen
  • onurka
    • Feb 2015
    • 17
    • Europa
    Hi everybody
    I need your helps.
    My children put 220 vac to coaxial sattalete input on the tv.😭
    After main fuse open to house.
    There aren't red blinking on the tv.
    Green led on.But screen is dark!
    What can I do?
    Regards.
    By Onur
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panasonic viera Txp50vt30e dark screen
    Red led blinks first and then turns to solid green? If so you got a bad mainboard.
    Search for the TNPH09 nr on the mainboard. If you use coaxial input for tv channels then also look at the white suffix sticker ( TXN/A.... ) .
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • Chrissygizmo
      Panasonic TX-48CX350B backlights but white screen , blank screen
      by Chrissygizmo
      Hi all, I’ve got a problem I hope someone can help me fixi.
      I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
      01-11-2025, 03:18 PM
    • Alicat
      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
      by Alicat
      Stopped by this site trying to fix my parents Panasonic Plasma TV.
      Model number is TH-50PZ85U
      Power comes on and the red power light stays on solid.
      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
      I also hear a few clicks.
      I also think my parents said there was a thunderstorm and the TV failed after that.
      Section 6 in the service manual talks about power and no screen,...
      10-30-2024, 10:09 AM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
