Schematics for Toshiba 40xv645u
  • Solderjerk
    • Aug 2017
    • 16
    I'm playing with a toshiba 40xv645u power supply board that has no standby voltage. The board is a srv2194ww. I've got voltage up to the bulk cap but after that is where I keep getting lost on how it feeds the standby transformer. I was looking for a schematic but no luck finding one. I like figuring stuff out on my own so I'd like to try a schematic first before I actually ask for some help...anyone have a schematic or service manual?
    Re: Schematics for Toshiba 40xv645u
    Can we see good clear high res straight shot pictures of the top and the bottom side of the power supply board? We also pictures of the whole backside of the TV showing all the boards.
    Toshiba 75014697 (SRV2194WW, 68-AL43A) Power Supply
    http://www.shopjimmy.com/toshiba-750...er-supply.htm#
    Is it the exact same board you have?
    Check fusible resistor R840 (0.47 Ohms?) to see if it is blown or not.
    • R_J
      • Jun 2012
      • 9624
      The standby transformer (T841) is driven by ic801, I would check R840, it should read 0.47 ohms, if its open I suspect ic801 will be bad If pins 5 & 7 measure short the ic is bad
      • Solderjerk
        • Aug 2017
        • 16
        Yes that is the same board...
        Don't have it front of me right now but I will check it and report back...thanks
        Still would like to see a schematic tho to follow it, I'm still learning smps
          If you look up the spec sheet of that SMPS IC for the standby power supply; you will probably see the application notes schematic for that IC which more likely to be about the same circuit as used in your board.
          • Solderjerk
            • Aug 2017
            • 16
            Poked around alittle on the board...r840 is open, as mentioned, and it then feeds ic801 pin 5. Pin 5 & 7 are not shorted. 5 is not shorted to any other pins, 7 is shorted to 8. Ic801 is a mip2f2 ...pin 5 is a d and 7 & 8 are s so that should be ok. That's all I checked, had to leave for work
              09-06-2024, 05:27 AM
              09-06-2024, 05:59 AM
              Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
              This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
              09-06-2024, 05:33 AM
