Hi everyone! I'm having a strange problem with my Toshiba TV, which sometimes doesn't turn on, especially after a short time after I shut down it.
If I shut down the TV with the power button on the left while the TV is on and then I try to switch it on again, the green led appears but without any image or sound.
If I try to turn off the TV with the remote controller (or with TV's right panel), then I unplug the wall socket (or I press the power button on the left), when I try to switch it on again, the red led appears but I can't turn it on in any way (even if I try to keep the power button on the TV's panel pressed until the red led blinks).
If I turn off the TV with the power button on the remote controller or the control board on the right panel and then I try to switch it on again (with the remote controller) it usually works.
I assumes the problem is on the PSU, but I'm still a newbie and I'm not sure about that. I disassembled the TV for visual checking the PSU, but the capacitors don't seem to be broken. I also checked the rectifier, and it appears to be good.
Is there anyone who might have an idea about this problem?
Thanks in advance
Thanks in advance
