Toshiba Regza 42XV635D sometimes doesn't turn on
  • JackHack96
    • Aug 2017
    • 11
    • Italy
    Hi everyone! I'm having a strange problem with my Toshiba TV, which sometimes doesn't turn on, especially after a short time after I shut down it.
    If I shut down the TV with the power button on the left while the TV is on and then I try to switch it on again, the green led appears but without any image or sound.
    If I try to turn off the TV with the remote controller (or with TV's right panel), then I unplug the wall socket (or I press the power button on the left), when I try to switch it on again, the red led appears but I can't turn it on in any way (even if I try to keep the power button on the TV's panel pressed until the red led blinks).
    If I turn off the TV with the power button on the remote controller or the control board on the right panel and then I try to switch it on again (with the remote controller) it usually works.
    I assumes the problem is on the PSU, but I'm still a newbie and I'm not sure about that. I disassembled the TV for visual checking the PSU, but the capacitors don't seem to be broken. I also checked the rectifier, and it appears to be good.
    Is there anyone who might have an idea about this problem?
    Thanks in advance
  • CapLeaker
    Leaking Member
    • 8161
    Re: Toshiba Regza 42XV635D sometimes doesn't turn on
    I am not convinced at this point that this is a PSU problem. Could you upload high resolution, straight shot pictures of your PSU and the main board?
    • JackHack96
      • Aug 2017
      • 11
      • Italy
      Here they are:
      https://drive.google.com/open?id=0B-...XhzamtfcmVYVFU
      https://drive.google.com/open?id=0B-...lZ6OUp5Yjc0cWc
      • CapLeaker
        Leaking Member
        • 8161
        They are too dark and not high res enough to zoom in and read things off the boards. We need to be able to identify things written on the boards.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Can you also attach them to your post as attachments so that the images are on this site not elsewhere. This is more useful to anyone helping you and anyone looking at a similar fault at a later date.
          • JackHack96
            • Aug 2017
            • 11
            • Italy
            Ok, I'll try to make them brighter, as for the resolution, my smartphone has a 13MP camera, it's difficult for me to achieve a higher resolution (I do not have other cameras)
            I tried to attach them, but the image size is too big, that's why I had to upload it on Google Drive, but I can shrink them (but I'll loose quality)
            • JackHack96
              • Aug 2017
              • 11
              • Italy
              I scanned the boards at 300dpi
              https://drive.google.com/open?id=0B-...EVmcTJxeDMwWms
              https://drive.google.com/open?id=0B-...FlvQnBycm8zWFk
              https://drive.google.com/open?id=0B-...XFFa0NjR0VaaFE
              https://drive.google.com/open?id=0B-...GhxWkFGblF4M00
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Check C889 for any signs of damage and that it hasn't changed its value.
                • JackHack96
                  • Aug 2017
                  • 11
                  • Italy
                  I visual-checked the capacitor, but there are no evident sign of damage (nor bulges, the surface is super flat). My multimeter doesn't have the capacitance measurement option, but I can try to use the resistance method for checking the health of it.
                  • CapLeaker
                    Leaking Member
                    • 8161
                    There aren't any pin outs printed anywhere, so that makes it much harder. Basically there is STBY voltage always generated on the PSU. That goes to the main board, powering it partially. Once you hit that On button on the panel or remote, the main board will send a few signals back to the PSU. So I would be checking for the PSon, the BLon signals to be present at the PSU. That will determent what board we have to look.
                    When you turn on the TV and it will get the green LED no pic no sound, look and see if the backlights are on?
                    • JackHack96
                      • Aug 2017
                      • 11
                      • Italy
                      Yeah I read various tutorials even on these forums, but many of them assumes you know the pin outs... Unlucky as always
                      When I'm in the green led situation, the backlights do not turn on, as the PSU doesn't output the 40V to the inverter (I checked with the multimeter)
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Manual available from:-
                        Page 22 gives the connector voltages.
                        • JackHack96
                          • Aug 2017
                          • 11
                          • Italy
                          I tried to measure the voltage of POW_SIG pin in P810A when I press the power button, but nothing change. I tried to use an external 3.3v source and I poked the pin with it for a few second, and I can hear the "click" sound of the TV when it turns on (don't know it it's a relay or something similar), but the TV remains off.
                          I then tried to poke the BL On/Off pin on CN653 with the same external source, hoping it would have switched on the backlight, but it didn't work.
                          I'm puzzled, I don't know what to do next
                          • JackHack96
                            • Aug 2017
                            • 11
                            • Italy
                            Hey, now the TV has turned on by itself (it's one of its lucky moments) and I've just measured the voltages of the following pins:
                            On the P810A connector (PSU)
                            POW_SIG: 2.80V
                            POW_LCD: 3.30V
                            On the CN653 connector (Main)
                            BL On/Off: 3.30V
                            PWM: 3.30V
                            Normally these voltages are 0 when the TV is off.
                            (sorry for the double post, it seems there's no clear way to edit previous posts)
                            • CapLeaker
                              Leaking Member
                              • 8161
                              Sounds like a main board issue to me. Maybe a bad eeprom. Find the eeprom on the main board, freeze it with a can of air upside down and see if the TV will come on.
                              • attainteddragon
                                • Apr 2013
                                • 764
                                • australia
                                also check any ldo regulators on the main. might get lucky.
                                WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                                • JackHack96
                                  • Aug 2017
                                  • 11
                                  • Italy
                                  I never did like that xD
                                  Anyway I shorted the pins of the variuos eeprom, but no luck
                                  I'll doubt it, but now I'll check them
                                  • CapLeaker
                                    Leaking Member
                                    • 8161
                                    freezing didn't help?
                                    • JackHack96
                                      • Aug 2017
                                      • 11
                                      • Italy
                                      I tried to freeze it but it didn't helped.
                                      I searched on the web for a replacement of the mainboard, and it's not that cheap (also there is no one who's selling that part in Italy, so I've also have to pay import taxes).
                                      Well, I guess I'll stay with this annoying problem, I was planning to buy a new 4K TV anyway.
                                        09-06-2024, 05:27 AM
                                        09-06-2024, 05:59 AM
                                        09-06-2024, 05:33 AM
