Panasonic TX-40CX400B - 17IPS20 - DULLSCREEN+ON/OFF/ON/OFF fault
  • shepp
    • Mar 2012
    • 377
    • England
    Hi guys this has just come to me and im not too sure were I should be checking voltages etc.....Vestel board hahaha
    I seem to have a voltage bouncing around but not sure if im checking in the right place see attached photo
    the set powers up, the hmdi channel info comes up, then after a couple of minutes it will freeze then switch off and on again, its gradually got worse the more I do it......i.e the screen stayed on longer when it 1st started checking it
    there is no signs of burning any where or shorts on the board
    I have circle where the voltage is bouncing around, and also were there is a suspicious area in which the diodes read 0 both ways(not removed as of yet though)
    wanted to check the voltage properly 1st
    MAIN BOARD PINS
    1= 23v[25V ON] 7=
    2= 8=0
    3= [3.26V ON] 9=0
    4= [3.26V ON] 10=0
    5= 11=12V
    6=12V [11.9 ON] 12=12V
    the ones that are blank are reading mV and moving around
    Now all of a sudden the backlight is flickering a lot, but before I even took the cover off the set it looked very dull
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Panasonic TX-40CX400B - 17IPS20 - DULLSCREEN+ON/OFF/ON/OFF fault
    Replace the PSU.....
    • shepp
      • Mar 2012
      • 377
      • England
      hahahaha thanks for that amazing advice - not quite what I was posting on here for though
      im more of a component kinda guy especially when the PSU is like Β£40
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        OK, shepp...OK....If the diodes appear faulty....lift one end and re-test...then worry about voltages......from your questions I misinterpreted as you not having any knowledge...SORRY. my bad....
        • shepp
          • Mar 2012
          • 377
          • England
          Pulled the biggest diode off today and it has gone 0 both ways, in the attached Pic of the 2 diodes.
          the transformer in which they are connected is the 30068375 transformer not sure what that does but if its to do with the LED backlight then it would make perfect sense
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            When you replace the diode use the same type. That is, if its an ultrafast Schottky diode then replace with likewise.
            • shepp
              • Mar 2012
              • 377
              • England
              Yes Ultrafast one.. MUR460G - Β£2 off ebay so ordered it.....then found the same ones on RS for 0.34p ....typical
              • R_J
                • 9535
                Is this close? The values etc. do look different, but it might be similar
                It seem a lot of mfg's use the board and stuff it differently
                • shepp
                  • Mar 2012
                  • 377
                  • England
                  Originally posted by R_J
                  Is this close?
                  EXCELLENT Thank you
                  • shepp
                    • Mar 2012
                    • 377
                    • England
                    Right .... so ive changed the Diode and the screen is nice and bright now, but its still switching off rather quickly, it powers up, I press menu, scroll and then it freezes and switches off then powers back on and so the cycle begins
                    • shepp
                      • Mar 2012
                      • 377
                      • England
                      some components are not on this schematic? is this correct? I cant find C283 C284 and I have no 5v Q212?
                      some things not quite adding up
                      • R_J
                        • 9535
                        This schematic is most likely for a different mfgr. Its the best available at this time, if parts are different or missing on your board, go by your board not the schematic. Many times they use the same pc board for different models ie 32" -50" and add or change parts accordingly
                        This is 17ips20 - (R2) <----
                        If its made for Panasonic, Hitachi, Vestel or anyone else its made to that mfg's specs Do search for this board using images and see the different configurations
                        • shepp
                          • Mar 2012
                          • 377
                          • England
                          ok sound advice, I dont think I read your original post properly before, my bad, problem now is figuring out why its rebooting, voltages look the same on the pins of the schemes anyway apart from there doesnt seem to be any 5v any where
                          this is gonna be one of them where I may have to guess which board is faulty and at this moment Im thinking it could be the Main Board not the PSU, but Its a vestel so its highly likely to be the PSU.......im getting the meter back out to investigate further, ill see if I can find any thing else out that might help someone to help me....or maybe find the fault hahahaha :-D
                          • R_J
                            • 9535
                            Is this the 5 volts standby you are missing? try and follow the line back, it must lead to a regulator ic or diode and then check if its supply is working, I can't see the main board even turning on without 5 volts standby
                            • shepp
                              • Mar 2012
                              • 377
                              • England
                              Q212 for the 5v isnt even on the board its empty check pic no.2 right bottom corner of yellow box
                              and I cant find any 5v signals, found a 3.3 and 12v and 24v, think the 3.3v is for the backlight control and thats it, im gonna run through the testing again tomoz and post results just in case they have changed
                              • shepp
                                • Mar 2012
                                • 377
                                • England
                                right so its blinking 4 times twice, then when it reboots it blinks 3 times then 7 times
                                in standby I seem to lose the 24V off pin 1 and get 1.8v on pin 2
                                attached is the blink code info that I could find, any ideas anyone, im not familiar with the terms on the sheet, so is P-board is PSU and A-Board Main and also what is SU, SD, SC, SS-Board?
                                • R_J
                                  • 9535
                                  It may not use 5 volts for standby, it may use the 12 volts as standby? Standby must be working or you would not have a blinking led and any codes. The 24 volts will shut down in standby
                                  I dont have that manual
                                  NOTE: Those codes are for a PLASMA TV, This is an LCD tv correct?
                                  • shepp
                                    • Mar 2012
                                    • 377
                                    • England
                                    ok thank you
                                    • R_J
                                      • 9535
                                      Being that it is actually a Vestel produced tv I dought the Panasonic codes will apply
                                      • shepp
                                        • Mar 2012
                                        • 377
                                        • England
                                        will any 17IPS20 PSU work or have I got to look to match the other number on the board?
                                        • Rictech
                                          Panasonic SA-MAX770PU SMPSU board fault....
                                          by Rictech
                                          Hello everyone. πŸ˜€
                                          As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                          Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                          Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                          This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                          There are no devices that have exploded or otherwise show signs...
                                          08-26-2024, 01:05 AM
                                        • chockimon
                                          Panasonic TX-40AX630B has developed a fault
                                          by chockimon
                                          I bought a Panasonic 40" TX-40AX630B TV from Richer Sounds 7 years ago and it has developed a strange fault. If I attempt to press any button on the back of the TV or remote control (access media features etc.) the TV locks up for a few minutes or longer and sometimes goes blank. However, if I turn the TV off and on again and quickly select a channel it will work fine all day long, as long as I don't touch the remote or controls on the back of the TV.
                                          I've tried changing batteries on the remote, changing plug sockets and doing other things such as a...
                                          06-02-2022, 12:03 PM
                                        • fixxy88
                                          Panasonic 55DX600u second fault - panel brightness pulsing on right side
                                          by fixxy88
                                          After getting the backlights up and running a second fault has emerged on this TV. I was going accept defeat and move on but thought I'd have a quick look at it in case it was something simple. The right side of the display exhibits a panel brightness (not backlight brightness) pulse every 2-3 seconds in a stable timing.
                                          I poked about on the TCON test points and found one voltage that is fluctuating in the same pattern. VGH-ODD (Pin 47 of U10) is sitting at ~-6.5v then goes up to ~28v when the brightness pulses then goes back down to ~-6.5v again in a repeating pattern.
                                          03-22-2023, 02:58 AM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                          11-20-2024, 08:52 PM
                                        • howardc64
                                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                          by howardc64
                                          • Prior owner tried a replacement main board. No difference.
                                          • Samsung 2x red blinking standby LED = panel fault
                                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                          07-19-2025, 10:54 PM
