samsung pn58a550s1fxza thermistor and relay repair...oh and burnt pcb
  • Lloyd6202
    • May 2017
    • 59
    Alright i need help and a walk through for this repair..cause the board is damaged and im not quite sure where conections go and meet heres a pic and all parts have arrived
  • diif
    • Feb 2014
    • 6978
    • England
    Re: samsung pn58a550s1fxza thermistor and relay repair...oh and burnt pcb
    You need to remove all the burnt PCB first.
    • Lloyd6202
      • May 2017
      • 59
      Ok i have a dremel to grind out damaged areas
        That board is dangerously close to being unrepairable.
        Because that is on the mains side, you have an arcing risk.
        You need to remove all carbonised material and ensure that the live, neutral and earth terminals are all sufficiently isolated from the damaged material first.
        • Lloyd6202
          • May 2017
          • 59
          Yes i do realize there is alot of damage would i be better off just cutting a square hole. And then patch it
            First try to remove as much carbonisation using isopropyl alcohol or acetone (careful on the silkscreen print marks as acetone will remove them, component identifiers etc).
            Then use a bit of sandpaper to take anything else off that is left
            I wouldn't recommend cutting parts out, because then you'd have no way to support the replacement bits.
            With this level of damage I'd seriously consider ordering a replacement PSU because you may never be able to safely repair it.
            • Lloyd6202
              • May 2017
              • 59
              Ya i think thae worst case senario is it wont work but the best case scenario is all works well and it was cool learning experience...i waited on these parts for almost two months now. So hang out with me and advice is always good...im gonna start this tommorow night
              • martino
                Not so "senior"
                • Aug 2013
                • 997
                • canada
                Is that a BN44-00183A? I can check tomorrow if I have one of those kicking around.
                Proud owner of dozens of broken TV's and many,many,many boards.
                Our website and passion:http://hollenhundshepherds.com/
                • R_J
                  • 9588
                  If it is the BN44-00183a, here is the schematic
                  The area that is burnt is where the 2 thermistors get connected in series, should'nt be too difficult to connect them together above the burt area.
                  • Lloyd6202
                    • May 2017
                    • 59
                    Sweet thanks for the schematic and yes if u do have that board kicking around can u sen me pic of both sides of board
                    • Lloyd6202
                      • May 2017
                      • 59
                      That might work i was just gonna fill in with epxoy and copper then heat tape redrill hole and thats that i think
                      • Lloyd6202
                        • May 2017
                        • 59
                        All good shes up and running boy thanks again
                          09-07-2024, 05:50 AM
                        • Journey11
                          Samsung TV won't turn on ... keeps cycling the power relay on & off
                          by Journey11
                          Hi All,
                          First time posting here ... my name is Kevin but my friends call me Journey.
                          I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                          After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                          It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                          07-04-2024, 02:44 PM
                          09-06-2024, 11:40 PM
                          09-06-2024, 08:40 PM
