Toshiba 40L1333DB Vestel 17ips20
  • jonny78
    • Apr 2017
    • 72
    • United Kingdom
    Got this set and its completely dead power supply is 17IPS20 with barcode 23122636..the faults are a carbon copy of this video from reeceyburger :
    https://www.youtube.com/watch?v=x7vnoqcTbQM
    rather than repair.. id like to replace the whole psu but the exact 17ips20 with right barcode I want seems to be a lot more expensive than other 17ips20..so my question is it strictly necessary to replace the board with the exact matching barcode? I was under the impression it was... I'm sure this question has been asked a thousand times but ill ask it again! lol!
  • jonny78
    • Apr 2017
    • 72
    • United Kingdom
    Re: Toshiba 40L1333DB Vestel 17ips20
    anyone? the panel in this TV is ves400unds-02-b I've seen this panel in some other vestel sets like polaroid.. so if I take a 17ips20 psu from a polaroid with a different barcode but with the same panel will it potentially work? I'm getting bombarded with TV's at the minute and haven't really got the time to repair much at the min need quick fixes!
    cheers!
    • diif
      • Feb 2014
      • 6978
      • England
      Why not give it a try ? I thought it was the mainboard, the stickers were important on, not the power supplies as long as the pins and voltages are the same. I know I've swapped Vestel power supplies before.
      If you need a hand fixing let me know. I'm based in Leicester.
      • jonny78
        • Apr 2017
        • 72
        • United Kingdom
        yep I'm definitely going to give it a try! wow... whereabouts ? im near wigston you?
        • diif
          • Feb 2014
          • 6978
          • England
          I'm near the space centre.
          • leo-saphira
            • Feb 2015
            • 32
            Hi. Did this method work. I have the same 40L1333 guy whom I got it from.tempted to repair the said board using the eBay kit and made a right royal mess of the job. Feel its safer to just replace the faulty power board. Got few 17IPS20 from other models.
            • Rickig
              • Mar 2015
              • 112
              • England
              Any update on this post?
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                There MUST be some difference with each board. I would want to match the voltages and also the connectors. Even if the connectors are different, I would try rewiring for them to match. The Backlight voltage should be close, also. If it looks reasonable and you are sure the PSU is the original problem. I'll give the all clear to give it a try.
                • alerton
                  • Dec 2018
                  • 86
                  did this work for you please?
                  • psdavid65
                    Toshiba 40L1333DEV Vestel 17IPS20
                    by psdavid65
                    Quick Question Please.
                    Is low resistance on gate pin 5 of U202 normal? I have a very very low resistance of 5 ohm on this gate. In diode mode, it looks shorted and beeps. Is this a normal behavior of this FAN6300 IC?
                    All other components on this vestel board have valid readings except for this U202 IC.
                    09-21-2023, 12:29 PM
                    09-06-2024, 05:27 AM
                    09-06-2024, 05:59 AM
