Sanyo DP42740 keeps blowing the two fuses at the main power cord connection. I have replaced both and they continue to blow when I plug in the power cord. With everything disconnected from the power supply board, I connected each cable one at a time to try to determine when they blow. When I connected the analog board the fuses blew. Don't know if this has anything do with it or not. Any ideas? Thanks in advance.
Sanyo DP42740 keeps blowing fuses
Tags: None
Re: Sanyo DP42740 keeps blowing fuses
No, it does not blow the fuses when just the power cord is connected.Comment
Amaybe that's also a clue where to look.
by sam_sam_samAbout a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer... -
by Sik_6ty_SixxSo like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...5 Photos
TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...-
Channel: Common Parts Library - Datasheets
10-07-2024, 06:07 AM -
by sam_sam_samI was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
This metal lathe has a weird motor setup it has a soft start motor with a “Y” and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not... -
by mon2Hi. New to this side of the forum.
Have an audio amp (Gemsound PXA-105) that keeps blowing the 3A fuses upon power up. Owner stated that the amp was on when he plugged in the input (mixer board) and that started this chaos.
Would a schematic be available? Advice on what to check? Power supply / output amp transistors? Do see the power on green led turn on for a brief moment before the fuse blows.
Thanks.
10-30-2024, 08:33 AM -
- Loading...
