Hyundai LCD TV. 5VSB PSU fault, but where to start?
  • jesterace
    • Aug 2013
    • 87
    Hi i have this Hyundai 37" LCD TV that had no standby light and was buzzing. Inspection of everything didn't find any dark or burnt components. No capacitors are bulging, all diodes that i could see test fine in diode mode.
    The 5V standby line was pretty low. 3.5v and fluctuating. On occasions i found the 12v line to be up and down as well.
    To troubleshoot so far i disconnected the 5v line from the mainboard and powered on again. This time, the 5v standby line stayed steady at 5.10v!
    Thinking that it was a mainboard fault, i injected 5v into it's standby line with a bench supply and looked for hot components. A 1.8v regulator was burning to the touch. However, right next door to is it was another 1.8v regulator (connected in parallel!). Weird that only one was hot? Some kind of imbalance here with the way they are loaded??? or is it the case that one takes over from the other when current demand goes up? Either way, both regulators were pumping out 1.8v just fine, despite one being pretty hot.
    Anyway, clutching at straws i decided to hook everything back up and inject 5v standby from another PSU (a computer ATX psu). Now the TV is working just fine, so it's clear that the 5v standby line on the TV's PSU has a fault?
    Now i'm wondering where i can start. What kinds of things can cause a 5v rail to drop and fluctuate like that? It starts about 2v and rises slowly to 3.5, and jumps about. It seems that the instability only happens when the 5v line is loaded. When disconnected from the mainboard, it reads 5v. My bench supply said that the 5v line of the mainboard was drawing about 0.6a @ 5v.
    I'm just really interested in electronics. I have plenty of kit because i enjoy learning. Any help would be much appreciated.
    Thanks,
    James.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Hyundai LCD TV. 5VSB PSU fault, but where to start?
    Need good clear straight on pictures of back of tv with cover off and each board.
    • R_J
      • Jun 2012
      • 9556
      How about a MODEL number, or number from the power supply?
      If you replace this part it will fix the problem.
      • tvguy12012012120
        by tvguy12012012120
        02-07-2025, 05:13 PM
      • howardc64
        Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
        by howardc64
        • Prior owner tried a replacement main board. No difference.
        • Samsung 2x red blinking standby LED = panel fault
        • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
        • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
        • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
        07-19-2025, 10:54 PM
      • mikey5791
        Tiny Tech ATX480W output power ticking
        by mikey5791
        Hi to all forum members,
        ​​​​​​This psu (Tiny Tech model ATX 480W) had been installed in a very old Windows XP PC but recently i pulled it out as the pc cannot start. To test it, i jumped the green wire and black wire on the 24 pin connector. The psu fan jerk a bit but not spinning. I used my dmm to check dc voltage on output connector wire, the 5v red wire keeps ticking a bit at around dc1v....then drops and ticking again around 1v. It is the same situation with the 12v yellow wire.
        Fyi, i desoldered the secondary side electrolytic cap those over 1000uf...
        02-20-2025, 01:11 AM
      • cheeky2
        LG 42LG3000 Strange fault will not go into standby!
        by cheeky2
        I have this LG 42LG3000 Tv which operates on all inputs without any issues whatsoever. However when you try to turn the Tv off the screen goes blank as it would normally however it then turns itself back on again!
        So far I have replaced the main board without any resolution to the problem.
        When the inverters master and slave VIT71053.54 VIT71053.55 are disconnected from the power supply then the TV will turn off as it should (obviously without any ccfl output).
        I have read through a few posts for this model without anyone having this issue as far as I can tell.
        I...
        05-04-2021, 06:02 AM
      • SoporteHR
        Help please, Line + 5VSB increases the voltage.
        by SoporteHR
        Hello everyone, receive a cordial greeting.
        I have an ATX 500W power source. Chassis Model: LPJ2-23.
        It turns out that when measuring the line voltage + 5VSB. After the source is turned on, the voltage gradually increases until it reaches approximately 7.8 vdc.
        If I leave it connected to the power but turned off, the voltage remains stable at 5.1vdc. approximate
        I thought I was a capacitor in that sector. Then I measured them with the ESR Raptor and they measured me well,...
        08-10-2019, 06:14 PM
