Samsung LCD TV 8 times blink red diode /wont turn on/
    09-07-2024, 05:50 AM
  • howardc64
    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
    by howardc64
    • Prior owner tried a replacement main board. No difference.
    • Samsung 2x red blinking standby LED = panel fault
    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
    07-19-2025, 10:54 PM
  • Jacksoft
    Samsung 225MW EEPROM bootloop
    by Jacksoft
    I got an old Samsung 225MW TV with BN41-00825 motherboard.
    Since the TV has a buzzer when it starts it makes a beep. The main problem is that the TV goes in a sort of bootloop and beeps every 2-3 seconds.
    So I attached the VGA UART cable and read the debug data using a RT809H programmer:
    According to the Service Manual all the voltages looks good, so I made a backup of the internal flash and all the EEPROMs (1 Settings + 3 EDID) and cleaned the EEPROM.
    Now the TV boots but it's stuck on VGA. If I try to change the source it goes to TV, restarts...
    02-14-2025, 04:18 PM
    09-06-2024, 11:40 PM
