LG 60PX950UA Main board issue
  • Mustangflyer
    • Jun 2017
    • 5
    Through the help of the forum, I believe I have a bad main board. Back story.
    TV turns on, panel primes, but has no video. Sound works fine along with remote controls.
    I jumped the CTRL board at R51 and R52, and unplugged the ribbon cable going to the main board and was able to get the Test patterns to display.
    Scowering the internet ive been unable to find the board in stock anywhere. I have found 2 places that say they can be repaired (unless the cant then they offer a refund).
    Im wondering if there is anyway to figure what has failed myself, save some money and learn a few things in the process.
    The tv was given to me from a friend, who had replaced the Y-sus and the lower Y Buffer and had given up on it.
    Any input would be appreciated! Thank you guys!
    Dan
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: LG 60PX950UA Main board issue
    BGA chip under that large heat sink? Knowing its a LG prob a reflow of that chip solves it.
    Also those barrel shaped caps can be suspect although I'd think you would get more of a intermittent fault.
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • Mustangflyer
      • Jun 2017
      • 5
      So should I pop off the heat sync and solder the joints together? Oven method?
      Heat gun?
      • Mustangflyer
        • Jun 2017
        • 5
        Is there a way to tell if the small board between the ctrl board and the main board is at fault? Or does doing the test pattern rule out that small board?
        • chrismurphy
          • May 2014
          • 251
          • australia
          Heat gun?
          Heat up the heatsink to make it easier to remove
          wipe the BGA chip surface with some smear of oil or Teflon spray
          Place a small c shaped piece of solder on the BGA chip
          Heat with a heat gun slowly until the solder melts
          works every time I have done this ,this assumes its the BGA chip issue and not something else
          • mmartell
            • Oct 2013
            • 3189
            Heat the chip thoroughly with a hair dryer then test the set for video to make sure this is your problem.
            • Mustangflyer
              • Jun 2017
              • 5
              Well heating up the chip worked! Tv is working great and looks way better than my old 50inch! Thanks guys so much. Couldn't have done it without you
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                It's not a guaranteed permanent fix but unless you know anyone who could reball the BGA chip it's really all you can do.
                • Asraf Atb
                  by Asraf Atb
                  01-27-2025, 05:02 PM
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • cheeky2
                  by cheeky2
                  05-25-2024, 03:27 AM
                • cheeky2
                  Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                  by cheeky2
                  For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                  See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                  01-08-2024, 05:56 AM
