Samsung UE50EH5300 main board BN41-01812A
  • TLFonderie
    • Feb 2017
    • 11
    • Europe
    Would a BN41-01812A extracted from a 40" working TV with a broken screen be working with 50" models? The reason why I am asking is because I have a 50" (UE50EH5300) with a dead main board, but before it died, I noticed that when into the service mode (see here: http://www.askvg.com/secret-service-...ony-and-lg-tv/), the board seems to be able to manage several panel references.
    I have managed to extract a working main board BN41-01812A from a broken screen 40" Samsung and would like to know if it can be used to fix my 50"?
    Apologies, my question may be silly because this must have been asked several times but I could not find a thread about this topic.
  • satinser
    • Oct 2012
    • 214
    • uk
    Re: Samsung UE50EH5300 main board BN41-01812A
    Are you now able to confirm whether it worked or not would appreciate your feedback
    • Asraf Atb
      Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
      by Asraf Atb
      Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
      Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
      I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
      01-27-2025, 05:02 PM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • Lee M.
      Samsung UN75RU8000FXZA bad main board?
      by Lee M.
      When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
      11-08-2023, 07:46 PM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • JDC
      by JDC
      ONN 100012588
      Long answer:
      07-15-2022, 07:39 AM
