LG 50PA5500 NO power
  • lajabba1985
    • Jun 2017
    So here is the problem. I have a LG 50PA5500 that took a power surge through the HDMI port. It would not power up or anything. I replaced the power board and still had nothing. So i disconnected all cables coming off the power board. When i plugged in to power i heard a click and herd some humming(good sound I hope). I then proceeded to plug in the cable that was near the slot labeled VATP on the power board all went well still have power. As soon as I plug in the cable going to the main board pt #EBT 62145301(where the HDMI ports are at) I loose power. With that being said do I have a bad main board too? I know when i check voltage i do have it at the cable that plugs into the main board.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: LG 50PA5500 NO power
    If you had power surge through hdmi then you will have damaged main board.
    • lajabba1985
      • Jun 2017
      Follow up. I have replaced power board(which gave me power finally, and replaced main board which has given me standby by power and ability to turn off and on, however i still have no picture. When I turn unit on i see a quick flash of the screen then nothing total blackness. Any ideas would be nice.
        Can you see some points on the control board (middle green board) marked EXT AUTO GEN
        Put a wire link between these then disconnect the cable between the control board and the main board
        If you see test patterns, the main board is probably at fault
        If not, something else is wrong.
        • lajabba1985
          • Jun 2017
          ooohhhhh pretty colors and movement. That worked I have a test pattern but I just replaced the main board, the original main board did not even allow a power up. Could the y sus or z sus be bad? Damn lightning did some damage. Thanks for the help tom66
            No since you got test patterns everything except the main board is good. I'm assuming all the colours looked good with no obvious distortion/etc.
            You got a bad main board, so send it back to the seller and ask for a refund/replacement.
            All too common for people to buy faulty boards and replace the wrong things.
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • JDC
              by JDC
              ONN 100012588
              Long answer:
              07-15-2022, 07:39 AM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • Destroyer-Br
              [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
              by Destroyer-Br
              I'm working on an Acer Nitro 5 unit with the following specs:
              • Motherboard: LA-J871P Rev: 1B
              • Model: Acer AN515-55-59MT
              • S/N: NHQ7JAL00403906A973400
              • SNID: 03902728734
              Initial Issue
              The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
              After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
              04-17-2025, 08:18 PM
            • cheeky2
              by cheeky2
              05-25-2024, 03:27 AM
