Fixed a Toshiba 40L1333DG TV with a 17MB95S-1 motherboard.
It was not turning on (no picture/backlight/sound), even though the microcontroller would get hot. Sometimes the power LED was flashing green/red.
The measurement on the PSU were good, except the DIM signal was 0V.
By flashing the firmware, the TV came back to life again.
At first I picked up a firmware which worked except that it was for the wrong panel, and such the colors were messed up.
Attached is the good firmware for this TV, found at http://www.elektroda.pl/rtvforum/topic3202664.html .
(splitted it in 2 parts because it's just above the size limit)
Procedure for flashing:
Grab a USB key, create one FAT32 partition, put all the files (mb90_en.bin, mboot.bin, usb_auto_update_A1.txt) at its root, plug it in the TV (I used the top USB port), hold the OK button on the remote and turn the TV on. Wait for the LED to start flashing (faster than the regular error blinking), you can release the OK button. When it's finished, the TV will restart by itself and show the configuration wizard.
I also attached some schematics for the PSU, not sure which one is the right one, but at least you get the pinout for the CN4 connector to the motherboard.
