UE32C5100 Standby Only
+ More Options
Posts
  • StephenU
    • Dec 2013
    • 230
    • United Kingdom
    Re: UE32C5100 Standby Only
    Mainboard
    • dskall
      • Oct 2016
      • 2905
      • usa
      You can try to narrow it down to specific area of board by heating sections at a time. I suspect maybe 3.3v regulator, ceramic cap or transistor bad
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        From my experience...When a section of board is heated up and set starts to work.....it is some e-cap bad....
        • dskall
          • Oct 2016
          • 2905
          • usa
          This board is pretty lacking in Electrolytics
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            +1...Sure right.....Made my comment without looking at the Bd. Perhaps then a solder connection expanding and reconnecting temporarily then contracting on cooling??......Hardly be a semi-conductor or resistor/
            • tvguy12012012120
              by tvguy12012012120
              02-07-2025, 05:13 PM
            • fharris1977
              Vizio D50u-D1 Dead Set No Standby
              by fharris1977
              Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
              12-28-2023, 10:25 AM
            • Crystaleyes
              Samsung BN44-00259A standby question
              by Crystaleyes
              Hi all.
              I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
              SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
              Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
              The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
              08-11-2023, 05:15 AM
            • psssst
              Yamaha TSX 120 Standby Problem
              by psssst
              Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
              03-01-2024, 07:25 AM
            • ChristianBr01
              LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
              by ChristianBr01
              I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
              The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
              What I already found is that the 12.8V are not an the connector to the main board connector to the power...
              04-23-2025, 01:48 AM
