Panasonic TX-P65ST50 Plasma Loud Buzzing
  • Eiji
    • Jul 2014
    • 21
    It's a 2012 model plasma TV. It seems like it has the loose screws issue as the buzzing is VERY loud with bright images and varies so much that it can't be ignored.
    The buzzing isn't just coming from one corner.
    Forget about my seating distance, the buzzing can be heard clearly from even 20ft away when the image is very bright, like a bee hive!
    I hope it's not the power supply on it's way out.
    Am I right that the back panel can be removed without removing the pedestal stand? It would make disassembly much easier.
    Looks like I need the XYN3+F6FJ-18PK screw set if it's the screws that are loose as the originals don't seem to have lock washers.
    Does anyone know of any equivalents to the XYN3+F6FJ-18PK that can be purchased from a hardware store?
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Panasonic TX-P65ST50 Plasma Loud Buzzing
    I have scrapped 100s of tvs and saved most of the screws. The ones from older Samsung tvs with lock washers on them are what I use. I hand tighten them so they cant strip out. Just match up the lenght.
    • tw2005
      • Oct 2011
      • 6458
      You could just tighten them up nice and firm and or a dab of non permanent loctite. I reckon they'll be M3 threads and then a matter of correct length as if they are too long you'll screw into the panel and crack.
      Pre-2011 models have the better screws. Any freebies you could strip a lot of screws out of?
      Or take a board screw out, take it with you and get the dimensions. Maybe a bolt store will have a better selection but you may have to get the washers loose.
      • tw2005
        • Oct 2011
        • 6458
        True, I've used some too and pretty close to the panasonic bolt.
        • Eiji
          • Jul 2014
          • 21
          The existing screws already had lock washers on them. I tightened some of them up but it made no difference, loud buzzing is still there. What else could it be? The sound isn't coming from just the top-left board (looking from the front) and when I run the screen wiper the buzzing sound follows the white bar from left to right so it's not a localised sound.
            That sounds like the panel itself is buzzing, so make sure they put the rubber spacers in place between the frame and the panel. You will have to take the facia of the TV off to do this, but the TV will usually stand up fine on the stand and the panel should be attached to the frame (though be very careful to make sure it is, otherwise it might fall and crack)
            • stecos
              Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
              by stecos
              Hi everyone!
              I happened several times, in the search for help from the web, to consult this very interesting forum.
              So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
              Having said that I come to the gist of my post on the forum as the title suggests.
              For my passion for technology I'm now collecting several...
              11-28-2022, 11:39 AM
            • HonkBeep04
              Panasonic TC-P65ST50 plasma in protection mode after incident
              by HonkBeep04
              Hello everyone! I picked up this 65" ST50 plasma TV for $80 on Facebook marketplace two weeks ago. I have the basic electronic knowledge of a teenage computer geek, having assembled laptops and PCs and messed with soldering and software.
              This afternoon I decided to disassemble it to mitigate a buzzing noise. This is a well known issue for this TV ever since they were new. The popular solution is to replace the loose internal screws for ones with lock washers, preventing any future buzzing. I figured that I could just fully loosen and tighten all of the screws securing the...
              04-26-2022, 11:04 PM
            • tofik
              PANASONIC TX-P42X10Y Plasma TV damaged after a power spike
              by tofik
              Hello, I have an PANASONIC TX-P42X10Y Plasma TV, purchased new in 2009.
              Unfortunately plasma is not working at all after a power spike. Standby LED is not even working.
              I did some quick tests, YSUS + ZSUS MOSFETS and IGBT's are free from shorts, diodes on these modules seems to also be fine, buffer board is free from shorts as well.
              Anyway I focused mainly on the PSU, did some voltage tests with the results as below, I attached them on the photo (also please see attached PDF with the SERVICE MANUAL for this model, page number 43).
              I understand...
              02-17-2023, 02:34 PM
            • SACR
              Panasonic Plasma TH-P42X28K A-Board @ Mainboard Schematic needed
              by SACR
              I need Schematic A-Board @ Mainboard for Panasonic Plasma TH-P42X28K. Code : TNPH0842. I want to replace 1 MLCC but I don't know values (capacitance & voltage) & codes. Can someone help me? Thank you...
              11-20-2023, 11:53 PM
            • renech
              panasonic TH-42PC77U plasma television half screen problem
              by renech
              hello,
              I hope someone on this forum can assist me.
              I have a panasonic TH-42PC77U plasma television.
              the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
              i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
              I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
              I have read some posts that suggest the problem is related to the boards on the left...
              12-12-2022, 06:53 PM
