RCA LED50B45RQ LCD Flatpanel powers off right away
  • SurrealMustard
    • Jan 2015
    • 487
    • The United States of America
    Of course! Why didn't I think of that sooner!
    Originally posted by 102mm
    I just repaired this set. it was the LEDs shorted for me. disconnecting them i was able to power on just fine. when i opened it up i found LEDs on a few strings shorted.
    Ah, I think you might be right. Can't believe I didn't think to try that earlier, but it does indeed power on and run just fine with the backlights disconnected. Looks like I'll be exploring that as the next plan of action with this thing.
    • SurrealMustard
      • Jan 2015
      • 487
      Replaced bad backlights!
      Backlights indeed. Replaced a couple strings, and this one is back in operation.
      • DRLDallas
        Re: RCA LED50B45RQ LCD Flatpanel powers off right away
        Didn't want to start a whole thread for what is hopefully a super easy question. I've got a RCA LED55C55R120Q TV and the backlights have recently stopped working. Everything I've seen here indicates it is most likely bad LED's in this model, but I was hoping to verify before opening the TV. I have a RE46HQ1640 power supply. When I turn on the TV the backlights fire for a split second, then go off. If I measure from LED+ (either one) I get a top voltage of about 130VDC as the backlights flash, then it rapidly decays to 0V over about 35 seconds. The LED- give me a reading of 48.6mv which could just be meter error. If I unplug the LED connector and power up the board, I get 230V on the LED+ terminals and the same 48mv on the LED-. I don't have the test equipment beyond a multimeter.
        Is this what the power supply would act like if I had 'bad leds'?
        Oh an occasionally the backlights will actually come on but rarely. I haven't been able to reproduce yet to test voltages in that state.
        • dskall
          • Oct 2016
          • 2905
          • usa
          I would say open circuit in led's. Bad led or bad connections
          • malogro
            Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
            by malogro
            Hello all,
            I'm stumped on this guy, so wanted to see if anyone has any further ideas:
            Intro:
            This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
            Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
            04-14-2023, 04:44 PM
          • jose6326
            Samsung s32d850t powers off
            by jose6326
            Powers on as normal shows an image then powers off after 10 seconds
            I have to unplug it from the wall and replug to get it to turn back on but then shuts off
            No blown caps
            I searched for this model but nothing comes up...
            11-29-2024, 11:21 PM
          • Rekoo1997
            DELL Precision 3520 powers on automatically
            by Rekoo1997
            Laptop Model: DELL Precision 3520 Motherboard: CDP80 LA-E152P Rev 1.0 (A00)
            Issue: The laptop powers on automatically after being shut down.
            Actions Taken by Technician:
            BIOS reflashed
            Intel ME region cleared
            Result: Issue still persists
            Additional Observations:
            Power button reads 3.3V (normal)
            The problem occurs both when running on battery and when connected to AC adapter...
            08-07-2025, 08:48 AM
          • simwalsh
            Philips 47PFL4606 Powers on, works normal then powers off after a minute
            by simwalsh
            I am new to this forum and have searched for some answers with problems similar to mine.
            Philips TV powers on as normal for about a minute or less then click and no power at all not even standby light. If i disconnect from mains and reconnect it will power on again but for a shorter time. Once i leave it disconnected from main for a longer time it will power on for a longer period the next time.
            It sounds like a power supply issue?
            I have the board out and want to run some tests. Not sure what i should be doing but i put a 1k resistor across SB and +5v...
            12-04-2023, 04:03 AM
          • csmith
            Vizio D50u-D1 Powers up no picture
            by csmith
            I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
            Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
            supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
            issue. Set will power up with remote but not power off....
            07-11-2025, 11:52 AM
