so i got tab bond issues
  • petehall347
    • Jan 2015
    • 4450
    basically it has 2 tabs .both bad .thin black vertical lines ..about 5 one side and was one but now 3 on other side . i can make one side worse by pressing on tabs with a finger . the other side is better but still one line ..is there any hope with this at all ?
    42 inch screen if that matters ...
  • petehall347
    • Jan 2015
    • 4450
    Re: so i got tab bond issues
    tried some bits of foam but no use .. might try again soon .
    i would prefer to repair properly but not sure on the right materials to use . i seen some videos but no mention of the materials used .
    i figure it is scrap now so not much to lose apart from my time .
    https://www.youtube.com/watch?v=ci4OFwtD1cE
    • dskall
      • Oct 2016
      • 2905
      • usa
      I use the grey heatsink material like this
      http://www.ebay.com/sch/sis.html?_nk...72.m2749.l2658
      • Rozp
        70LE660U dark cloud or black screen with sound.
        by Rozp
        Hello Everyone,
        This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
        I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
        08-29-2023, 05:25 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • flibidy
        Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
        by flibidy
        I have here a Magnum IA.100 which belongs to my parents.
        The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
        Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
        What Ive done........
        01-01-2025, 01:26 PM
      • ttmi100x
        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
        by ttmi100x
        Greetings everyone,
        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
        Upon closer inspection...
        07-31-2024, 06:36 PM
      • Davidhames
        KDL-70R550A Peeled off LCD Tabs on left side and perfect picture for 5 minutes
        by Davidhames
        Hi Guys,
        Thought I might try and seek advice on an issue I am having, I got this SONY tv for free that was having some dark greenish colouring, I replaced the T-CON and too my suprise the TV would not boot - I would get 5 blinking red LED lights. I dug deeper into this forum and someone mentioned the fact that it might be the tabs that connect to the LDC panel, and peeling them off should bring back a clear image. I tried this on the side of the T-con that was causing the tv to not boot when plugged in (left) and wow a perfect picture and was booting up fine! All was well and good...
        02-23-2022, 08:21 PM
