Good day folks. Got this Samsung LE40R81b TV which doesn't turn on. When I opened it up, it indeed had some bad caps (pun intended
) on the power supply. I replaced those, power supply works like normal now, producing all the correct voltages, however the problem persists: when you plug it in, the LED comes on, the relay clicks, the voltages come up, but no picture is displayed and after a few seconds, the relay drops out and the process restarts. I read in this thread, that there could also be bad caps (pun intended again
) on the main board itself. While mine is not completely identical to the one in the other thread, I DO see some 1000uF caps similar to those. My board is a BN41-00839E. I attached a photo of both the board and the caps in question. His caps were under the shield for the CPU, while mine are out in the open and I got 4 of them, while he only had 2. I see some smaller caps under my shield as well, but not having an ESR meter, taking the shield off would be nothing but a waste of time. Should I try replacing the ones on the outside first? Someone else said it could be an EEPROM issue....I've recently acquired one of those cheapy BIOS/EEPROM programmers from ebay, so I COULD work into that if it proves to be an option. Any thoughts ?
