Samsung LE40R81b not turning on (relay clicking on and off)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. Got this Samsung LE40R81b TV which doesn't turn on. When I opened it up, it indeed had some bad caps (pun intended ) on the power supply. I replaced those, power supply works like normal now, producing all the correct voltages, however the problem persists: when you plug it in, the LED comes on, the relay clicks, the voltages come up, but no picture is displayed and after a few seconds, the relay drops out and the process restarts. I read in this thread, that there could also be bad caps (pun intended again ) on the main board itself. While mine is not completely identical to the one in the other thread, I DO see some 1000uF caps similar to those. My board is a BN41-00839E. I attached a photo of both the board and the caps in question. His caps were under the shield for the CPU, while mine are out in the open and I got 4 of them, while he only had 2. I see some smaller caps under my shield as well, but not having an ESR meter, taking the shield off would be nothing but a waste of time. Should I try replacing the ones on the outside first? Someone else said it could be an EEPROM issue....I've recently acquired one of those cheapy BIOS/EEPROM programmers from ebay, so I COULD work into that if it proves to be an option. Any thoughts ?
    Wattevah...
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Samsung LE40R81b not turning on (relay clicking on and off)
    i think with these sets you can fit a blank eeprom and it rewrites the default data maybe see this thread
    https://www.ifixit.com/Guide/Samsung...lacement/14574
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      UPDATE: I replaced all of those caps and it did NOT solve the issue. I guess it's on to the EEPROM...no idea where it's located though.
      Wattevah...
      • vinceroger69
        • Mar 2012
        • 6714
        IC1803 on back of mainboard?
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          The board in the link you provided is not the same, although IC803 appears to be the EEPROM on my board also (ATMEL 740 24c256BN). I don't have a blank one on hand, so I was thinking of removing it, erasing it and putting it back in place (after saving whatever's on it of course). The TV's busted anyway, so no way I could make it worse by doing so
          Wattevah...
          • vinceroger69
            • Mar 2012
            • 6714
            I would try it nothing too loose there is various firmware around but depends on your lcd panel number etc if its the correct type.
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              Tried removing the chip and running it through my EEPROM programmer, but didn't get anything off of it. It could be that the chip itself is busted and needs replacing.
              Wattevah...
              • attainteddragon
                • Apr 2013
                • 764
                • australia
                try freezing the chip and see if you can read it then.
                WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  UPDATE: I DID manage to read and erase the chip after all: turns out I had it inserted into the 25xxx slot of my programmer, when it was supposed to go into the 24xxx, hence the name. Anyway, now the TV DOES come on and seems to work fine, but only for about 20 seconds - then it reboots and the cycle repeats...thought I'd keep you guys posted.
                  Wattevah...
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    theres another thread on this forum with that same issue i will see if i can find it
                    Edit! No follow up so not sure if new eeprom solved the issue
                    https://www.badcaps.net/forum/showthread.php?t=16708
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      • Romania
                      I think I found it at one point but never actually got the solution...it sorta died off :|
                      Wattevah...
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        its odd your sets sort of working now i wonder if you can find what ic the eeprom is re writing the data from once found that ic clear the eeprom again and freeze spray the other ic then start the set up as it may write more data too the eeprom?
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          • Romania
                          I'll try it with a new chip and see if that makes a difference. If not, I'll have to get a whole new board.
                          Wattevah...
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            You could still have a bad cap and causing restart and eeprom corruption. Maybe you can measure across caps in ac mode or if you have oscilloscope for noise.
                            • Dannyx
                              CertifiedAxhole
                              • Aug 2016
                              • 3912
                              • Romania
                              No scope sadly...what should I be looking out for with the regular meter ?
                              Wattevah...
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                Here's a video may or may not help find problem
                                https://www.youtube.com/watch?v=LvXe0bOF_mk
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  • Romania
                                  Oh I get it. Neat little trick
                                  Wattevah...
                                  • attainteddragon
                                    • Apr 2013
                                    • 764
                                    • australia
                                    what eeprom reader/writer did you get? i know a couple of us are looking at getting one and any info you have would be awesome.
                                    thanks.
                                    • Dannyx
                                      CertifiedAxhole
                                      • Aug 2016
                                      • 3912
                                      • Romania
                                      It's not too big a deal and I haven't had any significant achievements with it to be fair - we got it rather cheap from ebay or aliexpress just so it'd be there if need be. I don't have it on hand right now to show you pictures, but it looks like this. The idea is you plug the thing in, install the drivers which I can't recall where my mate got from honestly and then you either solder the chip onto the programmer board itself to access it, or get yourself a little riser board with a clip which clamps onto the chips directly so you don't have to solder them anymore - looks like this, but we had to get it separate from the programmer. It presumably also allows you to read the chips while still on the board, but I tried it several times and it didn't work, so either way you pretty much HAVE to remove the chip, though that could be down to individual chips or the programmer itself. The trouble is not so much accessing the chips, but having something to write back on them, as finding the correct firmware is difficult or impossible. You might have some limited luck erasing the chip and putting it back in, like I did here, but as you can see it only worked half-way as the TV still power cycles. For computers, a blank BIOS chip is obviously never gonna turn on that motherboard again, so make sure you back up what's on the chip first and THEN mess with it - you might even get lucky to find the firmware somewhere, like we did for a Toshiba laptop.
                                      Wattevah...
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        thanks.
                                        I also have the same programmer as dannyx but also have one like this although you can get them a lot cheaper this was the first link i found with all the accesories
                                        http://www.ebay.co.uk/itm/TL866A-Uni...sAAOSwal5YEdaJ
                                          09-07-2024, 05:50 AM
                                        • Journey11
                                          Samsung TV won't turn on ... keeps cycling the power relay on & off
                                          by Journey11
                                          Hi All,
                                          First time posting here ... my name is Kevin but my friends call me Journey.
                                          I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                                          After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                                          It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                                          07-04-2024, 02:44 PM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
