Panasonic tc-p50vt25 problem with HDMI ports.
  • Ncdude
    • Nov 2016
    • 6
    • usa
    I sent the A board off to PTS and they repaired the TV turning off and on issue but now another has shown up.
    When I plug anything into the hdmi ports it does not recognize anything you plug in. Is there a simple fix for this problem? I am hoping I don't have to send the same board back to PTS.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Panasonic tc-p50vt25 problem with HDMI ports.
    I would speak too pts and see what they suggest as thay have repaired the board it maybe something they have seen before im not sure how to get into the service menu on these as you maybe able too see if hdmi is enabled etc.
    • Ncdude
      • Nov 2016
      • 6
      • usa
      Thanks, I reached out to them just before this post and I was curious if anyone on here knew anything.
      I appreciate your input.
      • vinceroger69
        • Mar 2012
        • 6714
        Do you know the background of the tv? maybe a lightning strike/power surge taken out the hdmi inputs?
        • dskall
          • Oct 2016
          • 2905
          • usa
          You could look up hdmi pin out and make sure you have voltage to it.
          • Ncdude
            • Nov 2016
            • 6
            • usa
            No power surge or lightning has happened and the rest of the tv works fine, I will look for a pinout on the ports.
            Thanks for the help and suggestions.
            • BadTelly
              HDMI ports not working - Panasonic model number TX-P50XT50B 50"
              by BadTelly
              Suddenly all HDMI ports stopped working on a Panasonic 50" TV. This is model number TX-P50XT50B and has worked fine for years.
              The TV turns on but no joy on either HDMI-1 or HDMI-2 and I've tested it using an input device and cable that works fine on another TV via HDMI.
              Thank you in advance for any help/ advice.
              Kind regards,
              Bad Telly
              11-26-2022, 11:26 AM
            • AquaMan Ua
              by AquaMan Ua
              05-17-2025, 09:40 AM
            • grimacelord
              Samsung UN50MU6070FXZA - HDMI Ports Not Working
              by grimacelord
              Hello. Samsung UN50MU6070FXZA here with both HDMI ports non-working. I have already verified multiple sources and multiple cables to ensure it isn't something simple like that as well as resets and software updates.
              I took the mainboard out and gave it a look. Nothing looks bad or burned. All of the HDMI pins are nice, none are broken at their pads either.
              Following the traces, it looks like both HDMI ports trace back to the main CPU which does seem to get hotter than I think it should despite it's (rather poor) heatsink.
              Since the HDMI controller appears...
              11-03-2021, 03:10 PM
              Lenovo ThinkPad P43s Mobile workstation P Specification for Upgrade or Repair
              This specification for the Lenovo ThinkPad P43s Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P43s boardview and P43s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
              09-06-2024, 09:40 AM
