Panasonic TC-P50ST60. 7 blinks
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    I believe one of the gurus has helped me out before with a similar problem with a salvage Panasonic plasma.
    The screen on this unit is very likely damaged, so it's not likely going to startup without some "forcing".
    When I first attempt power on after a long time with it unplugged, I get the loud buzzing noises, but was also able to hear mainboard function while i was pushing the control buttons. After less then 3 minutes, the set shuts down with 7 blinks, and won't turn on for awhile after that. I tried disco'ing the SC data and power connectors, but nearly the same result.
    Is there any way to force this set to turn on so that I could test sound and some mainboard function, or any of the other boards? Perhaps some combination of unplugging cables? Thanks!
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Panasonic TC-P50ST60. 7 blinks
    If it has a broken screen and you turn it on you are going to blow up the sc board and maybe the su, sd, or both.
    You can test the ss,sc,su,and sd boards out of the set, read some posts.
    What do you want to test on the mainboard?
    • tucocaps
      • Apr 2013
      • 331
      • United Stated
      Did some searching and jogged my memory. SC50 jumper That's the one to remember for salvaging. Jumped it, fiddled with controls, and got audio on HDMI on, key beeps, etc.. I'm assuming this means main and power are likely AOK, but I'll gladly toss SU,SD,SC,SS.
      • Andre Gilbert
        by Andre Gilbert
        11-20-2024, 08:52 PM
      • Nairolf
        Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
        by Nairolf
        I have a Samsung DM32D display.
        When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
        Here’s what I have tried so far:
        1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
        2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
        3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
        From these tests, I suspect the problem might be on the mainboard. Could anyone...
        08-24-2025, 03:47 AM
      • Biruslapio
        Panasonic P58V11B 8 and 12 blinks error "fix"
        by Biruslapio
        Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
        Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
        04-13-2021, 07:13 AM
      • jm1234
        Panasonic plasma TX-P42ST50 - 6 blinks
        by jm1234
        anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
        It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
        I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
        I checked that board for any obvious faults...
        05-22-2024, 06:59 AM
      • Alicat
        Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
        by Alicat
        Stopped by this site trying to fix my parents Panasonic Plasma TV.
        Model number is TH-50PZ85U
        Power comes on and the red power light stays on solid.
        Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
        I also hear a few clicks.
        I also think my parents said there was a thunderstorm and the TV failed after that.
        Section 6 in the service manual talks about power and no screen,...
        10-30-2024, 10:09 AM
