Panasonic TH-42PY80 plasma 10 blink error code
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Re: Panasonic TH-42PY80 plasma 10 blink error code
    Pff...yeah, vinceroger beat me to it while I was typing apparently
    Wattevah...
    • Fisher77
      • Feb 2016
      • 229
      I dont think it is going to matter at this point. IC8001 is also getting so hot I cant touch it. Is this the one you were refering to as the tuner Dannyx?
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        Don't have the schematic on hand right now, so I really don't know what IC8001 is, though I doubt it's the "tuner". I didn't have to remove the A-board from the one I fixed so I don't know what it looks like, but the tuner unit should be a metal box with the antenna plug on it and the tuner IC is usually inside, so you wouldn't normally have access to it and the schematics would probably have a separate schematic for the tuner unit rather than including it as parts of the A-board itself. What is IC8001 ?
        Wattevah...
        • Fisher77
          • Feb 2016
          • 229
          I have no idea. I have gone over the 12 pages of A board schematics 4 times, it is not there. All I have is a panasonic part number from the parts list: MN2WS0047.
          Like I said it gets hot. It does have a heat sink on it, but still, I dont think it should get so hot I cant touch it at all.
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            Searched for that model online and it's definitely some sort of processor...it should get hot obviously, but if it's as hot as you describe there's a pretty good chance it's toast. Might have to look for an entire A-board.
            Wattevah...
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              #26
              I'm digging up my old thread here, but guess what: this same TV is now dead It won't power up and the LED indicator doesn't turn on either. Haven't thoroughly measured the power supply yet, but I'm pretty sure the main board is dead since I do recall getting 5v on the standby pin...funnily enough it happened to me as well after somebody else was asking about a faulty A board around here KARMA !
              Wattevah...
              • cloo
                Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                by cloo
                I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                After doing a factory reset this problem was gone and the picture was back to...
                01-06-2025, 06:02 AM
              • rmacintosh
                Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
                by rmacintosh
                I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
                The symptoms of the tv ar as follows:
                • Plug AC in to back of TV
                • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
                • The 3 blink code is given by the power LED
                • If the TV is unplugged and then
                03-14-2020, 12:24 AM
              • jm1234
                Panasonic plasma TX-P42ST50 - 6 blinks
                by jm1234
                anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                I checked that board for any obvious faults...
                05-22-2024, 06:59 AM
              • orbit417
                Panasonic Plasma tc-p55vt50 6 blink error code
                by orbit417
                Hi All,
                Thank you in advance for your advice.
                I have a Panasonic Plasma tc-p55vt50 that's about 9 years old and has just recently stopped working :-(
                I noticed that when I turn the tv on I hear a click then screen comes on for like half a second then shuts off and the led blinks 6 times.
                I did some googling and found several video's on trouble shooting all sorts of blink codes. I finally came across one that showed 6 blink error code but for a different model. It recommended disconnecting the SC board to determine if it was the A board or power...
                04-14-2021, 09:11 AM
              • stecos
                Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                by stecos
                Hi everyone!
                I happened several times, in the search for help from the web, to consult this very interesting forum.
                So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                Having said that I come to the gist of my post on the forum as the title suggests.
                For my passion for technology I'm now collecting several...
                11-28-2022, 11:39 AM
