Pioneer plasma PDP-LX5090 does not start up
  • PowerAmpFreak
    • 982
    • Sweden
    This Pioneer plasma PDP-LX5090 does not want to start up.
    It does not even give a blinking code.
    It's most of the time stuck in standby (red led)
    Occasionally, it can go to start (blue led) but with no other sign of life.
    Is this problem related to mainboard(s) / logics rather than PSU ? Best guess?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Pioneer plasma PDP-LX5090 does not start up
    Best guess??.....Main Bd
    • pixelcap
      Pioneer Plasma 111FD To Solder or Not to Solder.
      by pixelcap
      Hello out there in Badcap land.
      I have a Pioneer plasma that gave me the dreaded 8 red blink and shutdown, I have been trying to trace the failure points. On my last inspection while replacing a Y Sustain Board I noticed on the original and replacement board some missing solder, the points of connection
      are from the Digital Address Board and the Buffer Boards. I have included the pictures, should I resolder these points or are they unsoldered intentionally? Any help would be much appreciated.
      Thank you
      Pixelcap...
      03-08-2025, 07:10 PM
    • Phil Stasik
      Pioneer PRO-FHD1 Elite Plasma Monitor Start-Up Problem
      by Phil Stasik
      Pioneer Pro-FHD1 Elite. Failure to power on.
      I'm new to this awesome forum, and have been reading like mad, but have not seen the answer to my challenge.
      We bought this Panasonic plasma monitor 16 years ago and it has never been serviced, so all parts are original, and the unit has never malfunctioned -- until about a month ago. The system fails to power on. At first (a month ago) this happened rarely. We learned to unplug for a few minutes to drain the caps, then re-plug, and the monitor would start normally. Now, we plug-in, turn on the main power switch, and the...
      01-19-2023, 01:22 AM
    • Bushcat
      Pioneer PL-X9 motor speed control wobble
      by Bushcat
      I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
      Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
      BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
      05-24-2023, 03:36 AM
    • EduCabral
      [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
      by EduCabral
      I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
      While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
      🔧 Details:
      • Model: YT-M06
      • Interface: Pioneer 1
      • MCU: Fujitsu MB89F202
      • Goal: Find a valid .bin firmware file or memory dump from a working unit
      I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
      07-15-2025, 12:26 AM
    • Wiggly_worm
      Pioneer plasma panel fault codes
      by Wiggly_worm
      Has anyone had any experience with with pioneer plasma panels, this one is in an NEC PX-42XR4G and it powers up for around ten seconds then goes into standby with a red led on digital board flashing six times and refuses to power up !...
      02-24-2020, 09:55 AM
