Pioneer PDP-50MXE1
  • wozzie
    • Dec 2014
    • 21
    Pioneer PDP-50MXE1
    HI hope some one can ? I have a Pioneer Plasma pdp-50mxe1 , it wont turn on . What its doing is stby red led is on when I go to turn it on green led comes on and I hear relays clicking , then it flashes 2 red led blinks .
    I have removed back cover and checked voltages . Stby voltage 3.3V is working and red led on power supply stays on . Have removed ysus and xsus board cables no difference . Have checked all supply rails to see if they come up for that brief second and they do . Is there a way to force power supply with a 1k resistor across stby and 3.3volt line ? Not sure where to start .
    03-31-2024, 02:12 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
    07-01-2024, 06:34 AM
  • shamsudeen
    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
    by shamsudeen
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply....
    07-19-2025, 07:14 AM
  • JimBanville
    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
    by JimBanville
    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
    09-13-2023, 07:21 AM
