Vizio E65-C3 Service manual
  • tech144
    • Jun 2015
    • 9
    • US
    No power....dead are the symptoms. I have no service info. Would like to get service manual or schematic. Thanks in advance.
  • SLK001
    • May 2014
    • 264
    Re: Vizio E65-C3 Service manual
    Good luck... Most manufacturers do not release either any more.
    • budwich
      • Jul 2015
      • 3097
      Your service manual will be your "eyes and a meter"... plus what ever guidance you get from here after you do some investigation of the set.
      • dskall
        • Oct 2016
        • 2905
        • usa
        If you would like help you will need to:
        Post good clear straight on pictures of back of tv with cover off and each board.
        Need voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
        Format:
        Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
        1 - XXXXXXX - XXv - XXXv
        2 - XXXXXXX - XXXv - XXXv
        3 - XXXXXXX - XXXv - XXXv
        4 - etc.
        • tech144
          • Jun 2015
          • 9
          • US
          Thanks....for all. Just have to use good old fashion troubleshooting skills. I will let you all know what I find. Cheers
          • tech144
            • Jun 2015
            • 9
            • US
            Okay, here is what I see on CN201:
            Pin 15 - No TCON on
            Pin 14 - No 12v TCON
            Pin 9 - Yes 12v
            Pin 8 - Yes 12v
            Pin 4 - No 12v Audio
            Pin 3 - 5v PS ON (stays at 5v)
            Pin 2 - 3.5v AC DET
            CN 301
            All 24v lines are active
            These readings are after set is plugged in, no control of on/off function.
            Is this bad PWR supply or Main board?
            • dskall
              • Oct 2016
              • 2905
              • usa
              Ps_on is 5v in standby?
                Pin 15 - No TCON on
                Pin 9 - Yes 12v
                Pin 8 - Yes 12v
                Pin 2 - 3.5v AC DET
                CN 301
                Can we see good clear pictures of the connectors and the labels? Also need good clear straight shot pictures of the top and bottom side of the board.
                Which version of the boards do you have?
                http://www.shopjimmy.com/catalogsear...q=Vizio+E65-C3
