TOSHIBA 48L1433DG no display
  • fpatrice2008
    • Oct 2015
    • 16
    • FRANCE
    Hy, My TV 48L1433DG is out.
    After firmare updated, Led backlight is ok, remote control is ok, but no display.
    I research complete firmware (3 files : mboot.bin, mb90_en.bin and usb_auto_update_A1.txt).
  • fpatrice2008
    • Oct 2015
    • 16
    • FRANCE
    Re: TOSHIBA 48L1433DG no display
    I research serial UART PC configuration to loging with my TV.
    I connected FTDI232-3.3v to input UART and start TV power.
    The font are illegible.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      You may be attempting to communicate at the wrong Baud rate.
      • fpatrice2008
        • Oct 2015
        • 16
        • FRANCE
        Thanks dick_barton,
        It's seems to me that baudrate is 115200.
        I use "termite" software
        If I change baudrate 9600 to 115200, is the same problem.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          The service manual should tell you what the set up should be.
          I would think it would be the same for all the Toshiba sets.
          Just going from memory there are quite a few variables
          The Baud Rate
          The number of Data Bits
          The Start Bit
          The number of Stop Bits
          Parity
          There's also a delay between reading data bits you can set so the buffer doesn't overrun.
          Edit
          Short the TX/RX line and enable Echo Character and check that what you type on the terminal is what you see coming back.
          • nimmay
            • Dec 2015
            • 82
            • Pakistan
            hello friendz i need bios dump of toshiba .... NWQAA LA6061P M/B Rev: 2.0
            • fpatrice2008
              • Oct 2015
              • 16
              • FRANCE
              Hy Duck,
              The baudrate is 11520 8bits, 1 stop
              I can send command :
              help
              and I have reply of my board 17Mb95S-1, but is not readable. No text.
              • gabiz_ro
                • Mar 2011
                • 171
                • Romania
                Use realterm
                In SPI flah ic (is for mboot.bin) i think is stored EDID for LCD panel.That's what I remember,maybe I'm wrong.
                When I'm on PC I'll check that.
                What firmware you used for update?
                What LCD panel are in TV?
                • fpatrice2008
                  • Oct 2015
                  • 16
                  • FRANCE
                  Hy,
                  Panel is : VESTEL VES480UVS-M01
                  At the begenning, my TV don't start, blinking led red/green (0.5seconde), no action with remote.
                  I read serial eeprom with CH341A. and compare with mboot.bin (firmware 10082828_27092518_40D1333B, 3 files), 50% of data are corrupt.
                  I copy mboot.bin in eeprom MX25L1606E.
                  After, I copy in USB flash mb90_en.bin with usb_auto_update_A1.txt
                  On start TV press ok and boot in USB flash is ok.
                  At end, remote controle is ok, backlignt is ok, but no display is present (logo, menu,...).
                  I suppose that the firmware is not compatible.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Put your EEPROM in the freezer for 10 mins then try reading it again using your CH341A.
                    If that doesn't work try heating it up but not too hot and try reading it again.
                    Don't know if this is any help
                    http://firmware-load.com/22189-toshiba-48l1433dg.html
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Duplicate reply. Removed.
                      • gabiz_ro
                        • Mar 2011
                        • 171
                        • Romania
                        I can't find firmware 10082828_27092518_40D1333B
                        On Toshiba support is only firmware with upgrade_mb90.bin file ,no mboot.bin.
                        What mboot.bin you used? Dumped by someone or from other firmware,most of dumped are 2MB but from other firmware may have only 1MB to preserve some setting,panel type,logo etc.
                        On mboot.bin at offset 0x01e1680 are 100h bytes with EDID.
                        Compare that area from original dumped bin with what you have now in mboot.bin.
                        • fpatrice2008
                          • Oct 2015
                          • 16
                          • FRANCE
                          Hy,
                          I used mboot.bin with 1MB not 2MB
                          no data after FFCCB, 1MB of course.
                          In the elektroda.pl forum, I find 2MB files for the 48L3433DG, same TV family
                          Topic is : Toshiba 48L3433DG wsad SPI
                          It's for same panel VES480UNVS-M01
                          Problem : I have not point enough to download this.
                          If you can or someone, thanks you ,very much.
                          • fpatrice2008
                            • Oct 2015
                            • 16
                            • FRANCE
                            I get the file.
                            At address 0x01e1680, it's good
                            I will do the test
                            • fpatrice2008
                              • Oct 2015
                              • 16
                              • FRANCE
                              This is the file
                              • fpatrice2008
                                • Oct 2015
                                • 16
                                • FRANCE
                                Result of the test :
                                KO
                                TV don't start, led is not lit.
                                RS232 message
                                0a 30 30 3a 20 fc .00: ü
                                • gabiz_ro
                                  • Mar 2011
                                  • 171
                                  • Romania
                                  From quick look at mboot.bin there are two kind.
                                  Like one you posted earlier
                                  On another one from other TV
                                  You can't swap them,are incompatible and result as kernel panic,doesn't know how too boot firmware from NAND.
                                  If dump are really from same type of TV try to upgrade again.
                                  Post your original,untouched dump first time made.
                                  • fpatrice2008
                                    • Oct 2015
                                    • 16
                                    • FRANCE
                                    Hy,
                                    Here I am at the starting point
                                    This file is the only one thats boots correctly.
                                    It's a similar file that I need
                                    • fpatrice2008
                                      • Oct 2015
                                      • 16
                                      • FRANCE
                                      Hy,
                                      I found used mainboard of similar TV.
                                      When I reveive it, I wil copy the Flash memory to store bin file.
                                      • fpatrice2008
                                        • Oct 2015
                                        • 16
                                        • FRANCE
                                        I received my mainboard Vestel 17MB95S-1, second and.
                                        I copy and saved the bin file of MX25L1606E whis CH341A tool.
                                        Unfortunately, the used board is KO, no start TV.
                                        I recopy the MX25L1606E bin file into old mainboard and tested.
                                        The TV start correctly and I have sreen now.
                                        But the picture is bad.
                                        I suppose the panel detect is not good. see the picture
                                        What is the factory reset mode ?
