TOSHIBA 48L1433DG no display
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: TOSHIBA 48L1433DG no display
    What control have you over the video Settings?
    • fpatrice2008
      • Oct 2015
      • 16
      • FRANCE
      Hy,
      There is no way to change type of panel, only basic configurations for input, sound, video but not resolution or other.
      Having copied the original file mboot.bin, I can flash my TV by USB and modify part of file "usb_auto_update_A1.txt"
      # <- this is for comment / total file size must be less than 4KB
      #mboot
      #For pure mboot.bin upgrade, use below part
      #fatload usb 0:1 80400000 mboot.bin
      #spi_wrc 0x80400000 0x00000000 0x0120000
      #For mboot_spi.bin (padded to 2MB, added logo, edid/ddr etc) upgrade, use below part
      spi_wrc 0x80400000 0x00000000 0x0200000
      What I miss is the full firmware because every time I have the wrong panel load
      Help mister VESTEL
      • Fatal_error
        • Oct 2017
        • France
        Originally posted by fpatrice2008
        I received my mainboard Vestel 17MB95S-1, second and.
        I copy and saved the bin file of MX25L1606E whis CH341A tool.
        Unfortunately, the used board is KO, no start TV.
        I recopy the MX25L1606E bin file into old mainboard and tested.
        The TV start correctly and I have sreen now.
        But the picture is bad.
        I suppose the panel detect is not good. see the picture
        What is the factory reset mode ?
        similar situation to me with my 48l1433DG, plus to all the image is turned upside down)) a solution I not have
        • Fatal_error
          • Oct 2017
          • France
          fpatrice2008, could you say if you have any way out of this situation? Thanks
            Not a panel fault. The panel configuration is wrong. Wrong firmware or panel.bin file.
            • rodayna2020
              • Aug 2019
              • mohamed
              #26
              merci merci merci merci
              • Willail
                • Jan 2016
                • 29
                • France
                #27
                Hello Fpatrice,
                I have some pb with the eprom of my tv Toshiba 48L1433DG. The tv doesn't work, stay in standby with red and green lights.
                I dumped my eprom coud you tell me if you found some errors? Could you send me your version?
                • lotas
                  • Jan 2016
                  • 4850
                  • Russia
                  #28
                  Originally posted by Willail
                  Hello Fpatrice,
                  If your TV does not turn on and the LED blinks red and green alternately, only USB firmware will help you.
                  • yokoono
                    • Apr 2010
                    • 511
                    #29
                    Hello Fpatrice,
                    Or this ??
                    • Willail
                      • Jan 2016
                      • 29
                      • France
                      #30
                      Originally posted by yokoono
                      Or this ??
                      Hello YOKOONO,
                      Thanks for the file. It is the same TOSHIBA 48L1433DG and TOSHIBA 48L1443DG.
                      Could you give me the procedure of the update of the firmware. I found that i have put the 3 files on a usb stick formatted in fat32. Then, i put on the tv of the bottom USB. Press the button OK and plug the tv. But, i don't have this button on my TV. Could you please help me?
                      • Willail
                        • Jan 2016
                        • 29
                        • France
                        #31
                        Hello Lotas,
                        How are you? Thank for your reply. Do you have the files that i used on my usb stick? Could you give me the instructions for this update?
                        • yokoono
                          • Apr 2010
                          • 511
                          #32
                          Hello YOKOONO,
                          1. Press and hold the OK button ON THE REMOTE CONTROL.
                          2. Plug the TV into 220v
                          3. The STBY LED flashes slowly and then quickly.
                          4. When it flashes quickly, release the OK button and wait for it to finish.
                          It may take up to 5 minutes.
                          • Willail
                            • Jan 2016
                            • 29
                            • France
                            #33
                            Thank a lot for the procedure.
                            You are the best !! the TV works again with the files that you send to me.
                            Thanks a lot
