Sanyo DP42D23 No picture, has sound, flashlight shows menu
  • phan1978
    • Sep 2016
    • 32
    Re: Sanyo DP42D23 No picture, has sound, flashlight shows menu
    I would like to thank both of you for the help. I really appreciate yall taking the time.
    • mrphys
      • Feb 2021
      ok so what was it?!?!
      I am having exactly the same issues, readings etc
        LCD LED TV Service Menu Codes
        TCL LED TV Service Menu Code
        LG LED TV Service Menu Code
        10-31-2024, 03:58 AM
      • howardc64
        M557-G0 no WiFi/Bt no WIFIVendor file?
        by howardc64
        Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
        • TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
        • Service Menu shows many Bt/Wifi info missing
        • Vizio app shows no WIFIVendor file
        Prior owner used enet and said turned off wifi somehow. It seems system config info for wifi might be missing. Anyone experienced this before?
        • Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
        10-15-2024, 01:12 PM
      • Retro140
        Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
        by Retro140
        So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
        To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
        06-18-2023, 06:13 PM
      • vf fa
        EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
        by vf fa
        Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
        I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
        So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
        01-31-2024, 01:40 PM
      • Rauni
        Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
        by Rauni
        Hello, this is my first post on this forum, and my first attempted to repair a TV.
        My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
        Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
        Read also that we should test what happens if we...
        10-01-2023, 12:06 AM
