Sony KDL50R550A picture shifts up & down
  • vt2nyc
    • Apr 2017
    Been looking for other people who have dealt with the same issue, but I haven't seen anything similar. While watching tv as usual, the entire picture started shifting up and down slightly. Probably less than an inch shift, back and forth every few seconds. Did all recommended troubleshooting: unplugging, factory reset, disconnected all cables, inputs, etc. It's definitely the tv, which is not under warranty. Did some online research and watched tutorials. Opened up the back and checked T-con board connections. Also checked T-Con board with multimeter. Less sure of what I was doing there, but all voltages were all string and steady. I just would like to know if anyone recognizes this problem and if it's repairable or if my 3 year old tv is DOA. Thank you for any advice/help/condolences. -- Heather
  • heavymachines
    • Mar 2011
    • 1028
    Re: Sony KDL50R550A picture shifts up & down
    Can you upload a video or multiple images of this problem?. This model is known for defective panels. But that may or may not be your problem. But images and video helps and you will get more help here.
    • CyberPhoenix
      Issue with picture quality of Sony bravia TV
      by CyberPhoenix
      Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
      01-22-2024, 02:08 AM
    • iglitare
      Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
      by iglitare
      i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
      Backlight seems to work, Sound (Setup menu after reset) works.
      If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
      Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
      With my small knowledge i would think at least the cables are good.
      Can this happen because of a bad tcon board?
      Or is it always a bad/shorted...
      09-04-2025, 07:13 AM
    • tree5656
      diagnosing sony XBR-75X900H. NO PICTURE
      by tree5656
      This tv is not even 3 years old. its a sony XBR-75X900H, it was like a flashbang went off suddenly, tv faded to black and no picture. backlight is on. tried to do the power cycle, factory reset. i get beeps from remote if i tap up/down but no picture. how can i determine if its the panel or a board? i have replaced boards before im just not sure what the issue is here. sony said nothing they can do and only suggested to find a local repair shop. please guide me here
      11-09-2023, 04:55 PM
    • DKWS89
      Sony XBR 49x900E - Sound and backlight on but no picture
      by DKWS89
      Hey Guys,
      So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
      All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
      12-14-2023, 04:30 PM
    • ronni
      Sony KD-43XE8005 with sound, backlight, no picture
      by ronni
      I have a Sony KD-43XE8005 with no picture on the TV when powered on. Audio and backlight work ok when powering on. Solid white indication light showing on front of tv bezel.
      When removing the left hand ribbon cable from the T-con board, a white image is displayed on that half of the screen and a black screen is shown on the right. If I gently rub the ribbon cable on the right an image or purple black bars appear. The cable doesnt appear damaged, and if swapped with the other ribbon cable the same flickering symptoms can be seen.
      Removing the LVDS cable results in...
      12-01-2022, 08:44 AM
