Toshiba bad resistor
  • BestYohman
    • Feb 2017
    • 29
    I have a Toshiba TV that a 5w 1.8 ohm resistor went bad. All I have on hand is a 5w 3 ohm resistor. Would I be hurting anything by using this?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Toshiba bad resistor
    The question you might want to be asking is why the resistor went bad.
      It sounds like the relay that is supposed to bypass that inrush current limiter is not functioning, better check the relay contact and the functioning of the relay, it is very common failure in Toshiba TVs.
      • dskall
        • Oct 2016
        • 2905
        • usa
        You can pull the cover off the relay and confirm if it is working. If it is functioning then clean contacts. Will need pictures of power board when you ask which relay it is.
        • BestYohman
          • Feb 2017
          • 29
          Someone else worked on this board... Horrible soldering and almost every point needed cleaned. Relay tested good and there is no fluctuating power at all. Idk if the horrible job that was done could have caused it but there was tons of corrosion from what looks like the rosin being left on. TV is on and working just don't know if it's safe to go up to the higher ohms.
            When you said the relay tested good, what is the contact resistance? The higher resistor's resistance the less inrush current but the AC Voltage applied to circuit will be less due to more Vdrops on the resistor so the circuit may not start up properly.
            What you have to test when the correct resistor is installed is to test and see if there is Vdrops on the resistor or not, it should not be if the relay is OK. You can use 3 Ohms for experiment to verify the relay condition for now.
            • BestYohman
              • Feb 2017
              • 29
              OK so it is not a permanent replacement and I'll have to order the correct one?
                Right now the important part is to verify that the relay is good for sure otherwise you will just burn up the new resistor, does that make sense?
                • BestYohman
                  • Feb 2017
                  • 29
                  yes i will check the relay now.
                  • BestYohman
                    • Feb 2017
                    • 29
                    one is 100.2 ohms the other is 269 ohms
                    • BestYohman
                      • Feb 2017
                      • 29
                      coil side...
                      • BestYohman
                        • Feb 2017
                        • 29
                        So do the relays need replaced?
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          Post #6 did you test like last sentence. Install resistor turn tv on and check across resistor for voltage
                          • BestYohman
                            • Feb 2017
                            • 29
                            just reading pins volts 84mv
                            • BestYohman
                              • Feb 2017
                              • 29
                              tested it multiple times just to make sure of the reading... tv does turn on and picture shows with resistor in.
                                So as long as the Vdrops on that resistor is staying low like that then the relay's contacts are good for now.
                                • BestYohman
                                  • Feb 2017
                                  • 29
                                  ok then the only thing now is ordering the proper resistor... correct?
                                    I would if you are going to sell the TV, but for your own use you can keep that sub resistor in place.
                                    • BestYohman
                                      • Feb 2017
                                      • 29
                                      OK thank you for all your help!
                                      • dskall
                                        • Oct 2016
                                        • 2905
                                        • usa
                                        BTW I believe that resistor is a thermal resistor with a 150c thermal fuse built in. If that makes a difference
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
                                          Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                          09-06-2024, 05:33 AM
