Philips plasma tv
  • lanada
    • Oct 2013
    • 50
    • Malta
    Philips plasma tv
    I have a 50PF7521D/10 with a Y MAIN board faulty
    The problem is it has the 4 zeners faulty (short circuit),can someone knows what are the part number or the zener voltage ???
    on the zener diodes it was marked P758ST but I cant 't find anything on google
    attached you can find the part number of board and where the zener is located
  • R_J
    • 9549
    Re: Philips plasma tv
    I believe these are the ones 755-UDZSTE-1733B (33 volt). Looks like 36 volt zeners would also work
    • freakaftr8
      • Oct 2012
      • 3743
      Common failure. Unknown as to why this happens but usually that repairs the ymain back to normal operation
      • lanada
        • Oct 2013
        • 50
        • Malta
        Are you sure it's a 36volts zener,because on the FUSE (F5004) that was blow up their was at around 700v dc.
        • caspian
          What Zener Diodes on a Linear Power Supply
          by caspian
          Dear members,
          I have a linear variable power supply with unknown brand name that I used for voltage injection.
          Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
          In addition, I discovered that its zener diodes are defective.
          I can replace the burned transistors.
          But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
          Therefore, I cannot replace the zener diodes.
          I do not want to test the zener diodes in a test circuit to discover their model or value.
          no schematics are available...
          05-26-2025, 12:38 PM
        • celiabrown
          Issue with Plasma Philips 37inch chassis FTL2.1
          by celiabrown
          Hello guys,
          My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
          Can someone has any symptom like this ?
          Thanks​
          05-09-2024, 10:56 PM
        • nev1001
          What zener diode might fix the sound on Maestro Mayhem gaming chair?
          by nev1001
          Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
          The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
          It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
          I think an issue could be a zener diode (or capacitor) which has shorted out.
          The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
          04-17-2025, 05:09 PM
        • G33RT
          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
          by G33RT
          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
          It does power up when pressing the power button.
          I already try the power button while plugin the plug with no result.
          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
          Could this be an PSU or eMMC issue ?
          07-19-2025, 03:43 AM
          NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
          by sam_sam_sam
          I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
          I bought this from an eBay seller but unfortunately they only had one
          I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
          I bought three of from them to also make battery packs with this output power limit in mind
          I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
          04-23-2025, 05:50 AM
