EV421VO Board 3642-1472-0150 DA2 Diode
  • dhack61
    • Aug 2010
    • 33
    Any body out there know where I can get this Diode.
    Markings KJJ Z5 It is the Diode beside the EPROM US4.
    Any help?
  • petehall347
    • Jan 2015
    • 4438
    Re: EV421VO Board 3642-1472-0150 DA2 Diode
    http://www.s-manuals.com/smd/kj
    • dhack61
      • Aug 2010
      • 33
      Thank You...
      • petehall347
        • Jan 2015
        • 4438
        be sure it tells you the correct things .. i have been nearly caught out with the lists being wrong or parts with wrong markings . some parts seem to have same marks and be different things .. schematic and understanding of circuit gets you a bit closer .service manual helps a lot .
        • dhack61
          • Aug 2010
          • 33
          If you know where to find a service manual for this unit, PLEASE let me know
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
            I was working on this CNC machine today found no keyboard functioning no control relay powering on
            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
            Found shorted diodes on main controller relays there are 3 of them that...
            01-07-2023, 05:43 PM
          • dennis_elx33
            NO BODY MARKING Diode
            by dennis_elx33
            Hello Everyone,
            I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
            While compared to the reading of another diode from the next channel it won't read at reverse bias.
            Now the problem is; it does not have any body marking.
            So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
            What do you think is this diode?
            Can you please suggest what part number can i use to replace this faulty diode instead?
            Hoping that you...
            06-14-2024, 12:36 AM
