Westinghouse 55" - mostly dead
  • boxtel964
    • Mar 2018
    • 5
    Re: Westinghouse 55" - mostly dead
    Changed main board and works good now. The cost totally C$82, thanks everybody's help.
    • Asraf Atb
      Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
      by Asraf Atb
      Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
      Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
      I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
      01-27-2025, 05:02 PM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • JDC
      by JDC
      ONN 100012588
      Long answer:
      07-15-2022, 07:39 AM
