problem with samsung ue22f5000ak
  • matir
    • Oct 2013
    • 16
    • italy
    Re: problem with samsung ue22f5000ak
    So it's not a problem due to the setting from the menu.
    It could be a problem with the controller?
      You have LED strip problem, and the pictures you upload are too small to be any help.
      What is the board P/N?
      What is the LCD panel P/N?
      • matir
        • Oct 2013
        • 16
        • italy
        the board is BN41-01987
        the LCD panel is AUO M 215HW03 V.1
        The controller for LCD panel is SLC5013R
        • matir
          • Oct 2013
          • 16
          • italy
          budm, the p / n writings are sufficient?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            If you are looking for help please could you post some high resolution picture as requested top and bottom of the circuit boards.
              09-07-2024, 05:50 AM
            • howardc64
              Samsung UN55JU650DF network/streaming problem
              by howardc64
              Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
              This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
              07-09-2025, 12:44 PM
            • alro7779
              Samsung UN55MU6103F video problem; has colored stripes on the display
              by alro7779
              Hello, everyone!
              A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
              09-27-2025, 11:29 PM
              09-06-2024, 11:40 PM
