problem with samsung ue22f5000ak
  • matir
    • Oct 2013
    • 16
    • italy
    I have a problem with a Samsung ue22f5000ak going on and off first quarter of the backlight at the bottom right.
    it is possible to obtain the schematics
    Sorry for my english but I'm using a translator.
  • matir
    • Oct 2013
    • 16
    • italy
    Re: problem with samsung ue22f5000ak
    The led panel is au optronics m215hw03 v.1
    • thoma
      • Sep 2012
      • 268
      http://www.samsung.com/uk/support/mo...22F5000AKXXU#n
      • thoma
        • Sep 2012
        • 268
        https://elektrotanya.com/samsung_ua1.../download.html
        schematic Wait until GET MANUAL appears!
        • dskall
          • Oct 2016
          • 2905
          • usa
          Very good translator
          • matir
            • Oct 2013
            • 16
            • italy
            can anyone provide me the electronic diagram of the LED display control
            • matir
              • Oct 2013
              • 16
              • italy
              No news ?
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                You may get mere responses if you post pictures of the screen so we could see the symptom you are getting. Also post clear focused pictures of the TV with back cover removed so we could see the layout of the boards. Thank you.
                • matir
                  • Oct 2013
                  • 16
                  • italy
                  Ok, now I provide
                  • matir
                    • Oct 2013
                    • 16
                    • italy
                    Ok here are the pictures of the display with the defect and the TV open
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      The panel specification says two light bars each having 64 leds in total per bar.
                      Each made up of 16 leds x 4 strings
                      I suspect you have lost the bottom right hand lower string of leds.
                      Edit
                      The pictures are to small to be of help.
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Possible bad connection or open wire on led string. Make sure that no wires going behind the panel are frayed or shorted to the frame. Sometimes the connectors that go into the light strips themselves behind the LCD panel can lose connection. But more thinking of possibly an open LED on that quadrant of the strip
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          Doesn't seem to be dark in all pictures
                          • matir
                            • Oct 2013
                            • 16
                            • italy
                            The lighting in the lower right is not always off, but is turned on and off every second.
                            The defect will diminish over time, but always persists
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              certainly sounds like a led issue maybe time to strip the lcd down and check them out.
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                LED turning on and off is usually a bad LED but remember it could also be related to an LED controller IC if it uses a certain type of balancing circuit. This controller would be located on the power supply does the flashing interval change or does he led come back on if you adjust backlight brightness
                                • matir
                                  • Oct 2013
                                  • 16
                                  • italy
                                  The controller is SLC5013R, but the brightness adjustment should not be on the entire LED bar?
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Not brightness, but backlight luminance control in the menu.
                                    • matir
                                      • Oct 2013
                                      • 16
                                      • italy
                                      Ok but control of the backlight luminance should not cover the entire bar and not just a part?
                                        Backlights level setting controls ALL the LEDs.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Flex NP950QCG-X01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-X01DE boardview and NP950QCG-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
