problem with samsung ue22f5000ak
  • dick_barton
    replied
    Re: problem with samsung ue22f5000ak
    Originally posted by budm
    You have LED strip problem, and the pictures you upload are too small to be any help.
    If you are looking for help please could you post some high resolution picture as requested top and bottom of the circuit boards.
  • matir
    replied
    budm, the p / n writings are sufficient?
  • matir
    replied
    the board is BN41-01987
    the LCD panel is AUO M 215HW03 V.1
    The controller for LCD panel is SLC5013R
    replied
    What is the board P/N?
    What is the LCD panel P/N?
  • matir
    replied
    So it's not a problem due to the setting from the menu.
    It could be a problem with the controller?
    replied
    Backlights level setting controls ALL the LEDs.
  • matir
    replied
    Ok but control of the backlight luminance should not cover the entire bar and not just a part?
  • freakaftr8
    replied
    Not brightness, but backlight luminance control in the menu.
  • matir
    replied
    The controller is SLC5013R, but the brightness adjustment should not be on the entire LED bar?
  • freakaftr8
    replied
    LED turning on and off is usually a bad LED but remember it could also be related to an LED controller IC if it uses a certain type of balancing circuit. This controller would be located on the power supply does the flashing interval change or does he led come back on if you adjust backlight brightness
  • vinceroger69
    replied
    certainly sounds like a led issue maybe time to strip the lcd down and check them out.
  • matir
    replied
    The lighting in the lower right is not always off, but is turned on and off every second.
    The defect will diminish over time, but always persists
  • dskall
    replied
    Doesn't seem to be dark in all pictures
  • freakaftr8
    replied
    Possible bad connection or open wire on led string. Make sure that no wires going behind the panel are frayed or shorted to the frame. Sometimes the connectors that go into the light strips themselves behind the LCD panel can lose connection. But more thinking of possibly an open LED on that quadrant of the strip
  • dick_barton
    replied
    The panel specification says two light bars each having 64 leds in total per bar.
    Each made up of 16 leds x 4 strings
    I suspect you have lost the bottom right hand lower string of leds.
    Edit
    The pictures are to small to be of help.
  • matir
    replied
    Ok here are the pictures of the display with the defect and the TV open
  • matir
    replied
    Ok, now I provide
  • Andrew F. Ali
    replied
    You may get mere responses if you post pictures of the screen so we could see the symptom you are getting. Also post clear focused pictures of the TV with back cover removed so we could see the layout of the boards. Thank you.
  • matir
    replied
    No news ?
  • matir
    replied
    can anyone provide me the electronic diagram of the LED display control
    09-07-2024, 05:50 AM
  • howardc64
    Samsung UN55JU650DF network/streaming problem
    by howardc64
    Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
    This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
    07-09-2025, 12:44 PM
  • alro7779
    Samsung UN55MU6103F video problem; has colored stripes on the display
    by alro7779
    Hello, everyone!
    A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
    09-27-2025, 11:29 PM
    09-06-2024, 11:40 PM
