Philips 42PUS7809/12 HDMI Fault
  • meeko
    • Feb 2017
    My Philips 42PUS7809/12 displays a black screen on all HDMI inputs but only for certain sources. (It knows a signal is received, by there is no picture or sound.) I've got another identical TV and this one works with the same sources/cables so it's most likely a fault with the main board.
    Can I replace the main board with one from the same series but different size screen (i.e. 55PUS7809/12)? I've found one for sale at a good price. Is it just a matter of changing the Screen Diversity Code and Option Codes to match the existing board? In the SAM I notice I can also change the model numbers so they look to be interchangeable.
    That is unless someone has another idea on what might be causing the black screen?
    Thanks,
    Steve
  • ivtec
    • Dec 2008
    • 1967
    Re: Philips 42PUS7809/12 HDMI Fault
    Thanks,
    Steve
    Use heat blower and try to heat up the Hdmi switch and the hdmi connectors on the main board ,some times solder connections on the Switches and on the connectors get bad,it could also be a bad Hdmi switch.
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • Wittie
      Philips 55OLED803/12 HDMI ports "half" defective
      by Wittie
      Hello everyone, Please excuse my poor English, but I'm using Google Translate ^^ I'm having a problem with the HDMI and USB ports on my 55OLED803/12. It's no longer possible to connect an HDMI device and see the picture. No matter which port I use, it only recognizes the device as an input source and displays it in the list (BD player, Fire TV, etc.). However, the actual picture doesn't appear in the same state. My home theater system also runs via the BD player - it still receives a signal and plays the sound correctly (e.g., from the TV program or an app like Netflix). This works with both HDMI...
      03-19-2025, 09:38 AM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • mavaro
      MSI GF63 MS-16W21 - Black Screen LCD - Working HDMI
      by mavaro
      I have an MSI GF63 laptop with a MS-16W21 motherboard on my table, and there is no image on the LCD screen. However, when connected via HDMI, the image displays correctly.
      Voltages on the EDP 40-pin connector pins:
      3pin = 012V,
      5pin = 1.75V,
      6 pin = 5V,
      7 PIN = 3.3V
      32 PIN = 2.2V
      33 - 36 PIN = 3.3V
      38-40PIN - 19V
      PU21 - MP2143
      1 - 5V
      2 - 5V
      3 - 3.3V
      4 - 0V
      5 - 3.3V
      6 - 0V
      7 - 0.6V
      8 - 3.3
      Help me please ...
      03-12-2025, 04:39 AM
