Insignia NS-50L440NA14 : Vertical lines following the picture's colors
  • vizi0n
    • Nov 2014
    • 28
    I've bought this tv in hope for an easy fix but it seems like it is the main board (CV318H-R) that is the issue. I am wondering if anyone can help me try to figure out which part of the main board is the problem?
    Thanks!
    Here is a video of what it does:
    https://www.youtube.com/watch?v=atkX4NCd3Qs
  • afourtrackmind
    • Nov 2013
    • 10
    • Cananda
    Re: Insignia NS-50L440NA14 : Vertical lines following the picture's colors
    More info required.
    What have you done to troubleshoot so far?
    What are the conditions?
    Is this right off power up?
    Does it seem heat related?
    • vizi0n
      • Nov 2014
      • 28
      I havent done much as far as troubleshooting goes. I can say that this affects the picture on all inputs, and also affects the overlay menu.
      This is all the time. Wether it is a cold power up, after being warmed up, it never changes.
      I tried knocking on a few chips from different boards to see if the problem would go away but it doesnt.
      • afourtrackmind
        • Nov 2013
        • 10
        • Cananda
        Off the top of my head, I don't recognize the issue. That erratic flashing, to me, would possibly indicate a capacitor flaking out. That's where I'd start hunting.
        • vizi0n
          • Nov 2014
          • 28
          Unfortunately there are only about 15 small caps total on this tv set, really. I have checked them and they all see physically fine (not bulged at all). They are also very small compared to other tv sets I've worked on in the past. I will try to investigate further tonight.
          • aaronwt6
            • Apr 2013
            • 855
            • US
            Looks like a panel problem to me.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              This fault can be caused by a failing T-CON Bd, also
              • vizi0n
                • Nov 2014
                • 28
                thanks for your input everyone. I will continue investigating. But I'm very skeptical about a bad panel, as the lines would not go away every few seconds, wouldn't they?
                • vizi0n
                  • Nov 2014
                  • 28
                  Since I can't seem to edit the original post, just for the sake of keeping information in one place, I will quietly revive this thread with the solution.
                  The solution was pretty easy : reseating the ribbon cables between the t-con and the panel.
                  • Stanley1843
                    by Stanley1843
                    06-29-2024, 11:54 AM
                  • srs
                    Insignia NS-50DR620NA18 w/ large vertical lines & no picture
                    by srs
                    I'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
                    A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
                    I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables...
                    04-22-2023, 02:40 PM
                  • pni
                    LG 49uf695v vertical coloured lines
                    by pni
                    Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                    11-14-2025, 03:15 AM
                  • Falki
                    Colorful LCD Vertical Lines on Samsung ue55es8090
                    by Falki
                    Hello there, ive recently found an older 55inch Samsung SmartTV.
                    A similar issue has been posted as well but also with no actual response ...
                    08-12-2025, 04:19 AM
                  • visionbluedemon
                    Help. Sony kd-65x85dj vertical lines
                    by visionbluedemon
                    First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                    Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                    tried blocking LC lines too, but same results
                    is it lcd panel issue or tcon board issue?...
                    07-25-2025, 04:56 AM
